Author Topic: 1975 CB750 Carburetor Cleaning: *Throttle lever rod*?  (Read 791 times)
Offline Lone Star Rider
  • A gearhead my whole life, working on my first bike
« on: April 17, 2020, 02:11:01 PM »
Been taking apart my carbs on my build "College Project: 1975 CB750"(http://forums.sohc4.net/index.php/topic,182017.msg2107872.html#msg2107872), and the only thing I can't pull apart is the *throttle lever rod* (no clue what it's called). I've watched Hackaweek's carb rebuild on his '73 a few times through and saw his PO had drilled out the pin that keeps it from sliding horizontally. I've got some considerable residue gunking up the rod, but it still spins freely and doesn't seem like too much rust. Is there any way to remove that pin without having to drill/fab/etc.? If not I'll clean it as it sits:
« Last Edit: April 17, 2020, 02:12:52 PM by Lone Star Rider »
'79 CJ7 Renegade
'70 Jeepster Commando
'72 Jeep Commando...
And now the '75 CB750!
Offline JimM68
    • Firstgens.com
Re: 1975 CB750 Carburetor Cleaning: *Throttle lever rod*?
« Reply #1 on: April 17, 2020, 04:49:13 PM »
If it moves free , I wouldn't take it apart. In fact, I didn't.
And when I put it all back together the carbs are still in sync, so that's a bonus.
Sent from my moto z3 using Tapatalk
"Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming 'WOW What a Ride!'"
« Reply #2 on: April 17, 2020, 05:04:21 PM »
 I've owned many SOHC 750's since 1981 and have never had the need to take one of those carb brackets apart either. Might be more trouble then its worth. You can micro polish some of the steel a little to brighten it up. Enjoy the cleaning,easiest ones to do on big bikes,very simple and straightforward.
Online HondaMan
« Reply #3 on: April 17, 2020, 06:59:12 PM »
That pin is tricky to remove, and the 'repair' Honda listed for it after removal is to tap the hole with a 2.5mm tap and use a tapered-tip screw in the hole afterward, glued into place. Most of the racks had a little cover there with a screw inside and a seal or Cerrobend over the top of it to hold it in place, because the screw is not tight (otherwise the shaft won't turn). On ones like yours I have just dunked the whole ting into a bucket of gas for an hour and then hosed it off real good to clean it, then detailed it.
« Reply #4 on: April 17, 2020, 07:38:45 PM »
Thanks y'all!
'79 CJ7 Renegade
