Author Topic: Ignition Timing Problems  (Read 1588 times)
Offline 2legsbetter
  • Only me.......and others.
« on: April 18, 2020, 09:08:44 AM »
Hi Guys, Thought I would ask for some technical help. CB750K6 I have totally rebuilt this from the ground up.
Now I have been trying to time the ignition. Set the gaps at 14 thou.
1/4 - If I rotate the back plate to open at the F point its waaay out of position and can only get one securing bolt on [top one] the other holes are covered by the plate - see the picture.
If i set the plate with all three bolts and at best position its firing at the 1/4 marking before the F and T.
Now it runs in both positions but better at the 1/4 mark.
Have I got the camshaft timing wrong?
Can the camshaft be altered with the engine in the frame if its wrong?
Thanks for any help.
Allan Macintyre
Offline 1952paul0
Re: Ignition Timing Problems
« Reply #1 on: September 19, 2021, 04:46:09 AM »
No the camshaft has no bearing on the ignition timing. Are you using the correct points try a 12 thou gap. did you dismantle the advance and retard mechanism is the advancer fitted correctly on the crankshaft there is a locating pin is that present.
