Author Topic: re-usability of torque screws  (Read 895 times)
Offline _mark
« on: April 20, 2020, 01:15:59 AM »
Hi all. I'm rebulding the engine of a 750 K1.
I heard somewhere and in this video that the screws of the connecting rods cannot be tightened more than one time (if I understood correctly) because they become stretched to yield after first time.. I didn't found such info in the shop manual.
@time 2:58  & 15:09
Is that true ? I didn't found it in the shop manual. Are there any other bolts in the engine that are like these (0ne time only and to be replaced) ?
How can I proceed to check the clearances of connecting rods?
Thanks and Regards.
« Last Edit: April 20, 2020, 01:19:11 AM by _mark »
Re: re-usability of torque screws
« Reply #1 on: April 20, 2020, 01:24:24 AM »
They are fine to reuse as long as they are not overtorqued.
Some engines usetorque to limit bolts but these are usualy tightened by angle not torque
Offline _mark
« Reply #2 on: April 20, 2020, 01:35:47 AM »
Thanks. Considering that the story of my engine is unknown, is possible to determine if they have been overtorqued  ? thanks.
« Reply #3 on: April 20, 2020, 03:26:07 AM »
Not really, does it look like the caps have been removed before?
Offline _mark
« Reply #4 on: April 20, 2020, 04:34:12 AM »
do you mean the nut?
the seem to be never touched.
Offline DaveBarbier
« Reply #5 on: April 20, 2020, 04:35:44 AM »
If they are over torqued then they have been stretched. If they’re stretched then the thread pitch will change. If a nut threads down the entire diameter of the bolt then they’re fine to use again. I remember a post in the past couple months saying that the connecting rod bolts are NOT one time use.
Offline DaveBarbier
« Reply #6 on: April 20, 2020, 04:37:09 AM »
Bryan is talking about the con rod half circle cap that is stamped with 45 in your picture.
Offline DaveBarbier
« Reply #7 on: April 20, 2020, 04:39:38 AM »
And there are no other bolts that I know of in these engines that are torqued to yield. Even the head studs/bolts are fine to reuse assuming they’re in good shape and not rusted to #$%*.
Offline rotortiller
« Reply #8 on: April 20, 2020, 04:57:59 AM »
What you have to ask yourself is does the engine employ stretch bolts. If it did use stretch bolts the manual will tell you the fasteners are a one time use. Lots of shop manuals on line for you enjoyment.
Offline _mark
« Reply #9 on: April 20, 2020, 05:10:56 AM »
Yes, that I told in first post. There are a lot of rumors about this issue but in the shop manuals I checked there is not any reference about this. Thanks
« Last Edit: April 20, 2020, 05:13:21 AM by _mark »
Online Jerry Rxman Griffin aka MuthaF'er
« Reply #10 on: April 20, 2020, 08:01:12 AM »
Put your torque wrench on it and see what the numbers are
Offline rotortiller
« Reply #11 on: April 20, 2020, 02:30:14 PM »
Reuse the hardware, it's what is normally done with that engine.
Offline jakec
« Reply #12 on: April 20, 2020, 02:35:21 PM »
I was testing bearing clearance which requires that you torque them. One of min overstretched and broke (kept spinning before reaching target torque value and eventually snapped). So I replaced all 8.
If you're worried about it and taking connecting rods off, just see if they reach the target number. If so I would think they're good?
1970 CB750 K0
1977 CB750 Chop
1997 XR650L
Offline _mark
« Reply #13 on: April 21, 2020, 01:41:11 AM »
target number is 20 Nm pretty low number isn't it? I would say that who damaged them ,reached far high number but it's only a guess.
« Reply #14 on: April 21, 2020, 08:42:02 AM »
It is easy to see a bad bolt as the threaded portion tends to get "waisted" as it is the narowest part
