Author Topic: CB650 Cleaning accelerator pump nozzels without breaking bank.  (Read 413 times)
Offline jefe06
Hi All,
I hope everyone is staying healthy and sane with the quarantine.  I've read the carb cleaning manual and viewed several posts, and none specifically state if you need to brake down the carbs to clean the accelerator nozzle for each carb.  I know carb two should be fairly easy since I can just spray through the accelerator pump, but what about the other carbs?  I really do not want to break the bank.  I'm in the process of rebuilding my carbs and this is really the only thing left that I want to make sure to tackle before final assembly.
I have a 1981 CB650 with original carbs.
One other thing.  Is there a manual specific for the '81 CB650?  The ones I've been able to find only provide info for the other types of carbs used on earlier models and not specifically the 81 carbs.  There are little variations between these and later model carbs.
Any help would be appreciated.
1981 CB650C bone stock.
Offline jefe06
Re: CB650 Cleaning accelerator pump nozzels without breaking bank.
« Reply #2 on: April 20, 2020, 07:50:24 AM »
This manual is readily available on this site and you shouldn't redirect someone to a site where you need to sign up to download it.
