Author Topic: Non-destructive rust removal for steel parts  (Read 8344 times)
Offline old750
  • Hippy ass bike.
« on: February 10, 2007, 11:08:30 AM »
As seen on TV! One of Spike's truck / muscle car shows:
1 bucket to hold your part
1 table spoon of sodium carbonate (washing soda, NOT baking soda) for every gallon of water
1 clean metal bar
1 battery charger capable of 2 amps constant
stick your part in the tub, hook up the negative terminal to the part
stick the metal bar in the tub away from the part to be cleaned, hook up the positive terminal to it
turn on the charger set at 2 amps and watch the rust wash away. make sure to do this outside or in well ventilated area cause it creates hydrogen which goes boom boom.
don't use on non ferrous parts as they will get messed up.
Offline malcolmgb
  • What am I not? an
  • The BEST 400 four by far
    • malcnet
Re: Non-destructive rust removal for steel parts
« Reply #1 on: February 10, 2007, 02:59:56 PM »
I was told Baking Soda is best, particularly 'Arm & Hammer'
Malcolm
1977 CB400F
1973 CL175 K7
1976 XL175 - Sold
1964 CL72
1966 CA78
Offline TomC
« Reply #2 on: February 10, 2007, 03:19:38 PM »
Hi Malcolmgb
     No it is washing soda! But Arm & Hammer is the brand. That said try and find some! I have had no luck. Sodium Carbonate is also used to reduce the acidity of swimming pools. That is no problem to find. At least in the summer.
          TomC
TomC in Ohio
76 CB750 F1 Daily Rider
76 CB550 stalled project
76 CB400F Injured Reserve
Offline clarkjh
  • Expert? If only.
  • Surely and Samson are now Co-habitating
« Reply #3 on: February 10, 2007, 03:27:39 PM »
I have done this, it works but turns your metal black but it does clean up.  Arm & Hammer Washing Soda is with the clothes washing soap.  It also produces O2 and H gas.
James
SOHC/4 #3328
SOHC/4 Gallery: http://www.sohc4.us/gallery/v/members/personal/clarkjh/
1974 CB550, 40000 Miles
1980 GL1100, 102789 KM - Back on the road after a complete engine rebuild.
*** Why, oh why, is it always head gaskets with me?***
Offline malcolmgb
  • What am I not? an
    • malcnet
« Reply #4 on: February 10, 2007, 03:37:45 PM »
while over in the US recently I was asked by a friend to get him some 'Arm & Hammer' baking soda for this same purpose. I found it at a supermarket called A&P (Atlantic & Pacific).
So what is the difference between washing soda & baking soda if they are both Sodium Bicarbonate?
Malcolm
1977 CB400F
1973 CL175 K7
1976 XL175 - Sold
1964 CL72
1966 CA78
Offline nickjtc
  • I was numero dieci
  • Yamaha XT500 'Gromit'
« Reply #5 on: February 10, 2007, 04:19:08 PM »
Sodium carbonate (Na2CO3) vs. sodium bicarbonate (NaHC03). Two different chemicals.
Nick J. Member #3247
2008 Triumph Tiger 1050
1977 Suzuki GS750
Offline old750
  • Hippy ass bike.
« Reply #6 on: February 10, 2007, 07:18:45 PM »
Aparently both work but bicarbonate works better.
Offline sandcastcb750
« Reply #7 on: February 10, 2007, 07:54:11 PM »
A good rust remover for steel is a product called "Oakite" If you heat this product in water, it removes rust quickly and is even good on chrome. I have had good success with it. It is used in lumber yards that have steel saws to clean. Only removes the ferris oxide. And Paint. Wonderful to clean out insides of fuel tanks.
It is very bad for aluminum parts; dissolves them.
It reminds me of sodium hydroxide, or like "Draino"
Offline malcolmgb
  • What am I not? an
    • malcnet
« Reply #8 on: February 11, 2007, 02:22:03 PM »
where can you buy 'Oakite'
Malcolm
1977 CB400F
1973 CL175 K7
1976 XL175 - Sold
1964 CL72
1966 CA78
yesplease
« Reply #9 on: February 12, 2007, 06:05:46 AM »
This method was mentioned once on these forums, but I figure it's worth bringing up again since I probably wouldn't have found it if I didn't know what I was looking for.
« Reply #10 on: February 12, 2007, 06:19:24 AM »
http://www.oakite.com/
I got my OAKITE from a guy who had a lumbermill. He used to put a whole frame into the oakite, because he had industrial tank with heating system.
I used a propane torch to heat a little pot with chrome or steel parts.
Offline Magpie
« Reply #11 on: February 12, 2007, 09:00:08 AM »
If you're patient molasses works too. Here's a past series of threads on it. It worked for me.
http://www.sohc4.us/forums/index.php?action=search2
Cliff
Offline Magpie
« Reply #12 on: February 12, 2007, 09:02:41 AM »
Sorry the link didn't work. Just search "molasses". There's plenty of info/opinions there.
Cliff.
Offline old750
  • Hippy ass bike.
« Reply #13 on: February 12, 2007, 07:15:40 PM »
dude that looks unbelievable. It seriously looks like BS but I have to try that. I have never been able to properly clean the rust off my old Puch and I have to try this.
Offline Magpie
« Reply #14 on: February 12, 2007, 07:26:17 PM »
Thanks yesplease, I'll get on that method in the morning! I run out of patience with molasses.
Cliff.
yesplease
« Reply #15 on: February 12, 2007, 11:15:24 PM »
Np! I think works the same as molasses, but we can pick what strength we want the mixture to be. I should add it supposedly stripes the finish off of anodized Al, and will remove Cd or Zn plating.
Offline ChevelleSSLS6
  • Member #4051
    • my myspace, yay.
« Reply #16 on: February 20, 2007, 02:57:39 PM »
anything that's good that won't damage chrome?
"What about incomplete idiots?" -TwoTired
"What's a leakdown test?  I filled the cylinder that looks like this with some water and let it sit overnight. The water didn't go down any.  I thought that would tell me about the rings." -Dead Guy of AMCforums
1977 CB550f- sold
2007 Kawi EX650- curre
Offline old750
  • Hippy ass bike.
Offline UnCrash
  • Pass
    • My Blog
« Reply #18 on: February 28, 2007, 09:00:51 AM »
Yes!
I've looked at Oxalic Acid on that thread and wonder how my exhaust would turn out if dipped.
I suppose that it's worth a try.  I have enough in the budget for my rebuild to obtain a new exhaust anyway.
Cheers
