Author Topic: Wiseco 836 piston ring end gap  (Read 1090 times)
Offline david 750f
  • 1976 CB750F
« on: April 27, 2020, 04:48:32 PM »
Wiseco recommends .012 for the top ring and .014 clearance for the second ring.
I'm measuring .015 and .021, is this too large a gap? Should I get the next ring size up and fit them to the Wiseco recommendation?
I've checked with two sets of feeler gauges. I am taking the measurement one inch up from the bottom of the cylinders. The piston clearance is .002, double checked with a micrometer and bore gauge.
1976 CB 750F
Re: Wiseco 836 piston ring end gap
« Reply #1 on: April 27, 2020, 04:51:05 PM »
No, you don't want oversize rings. Those gaps are fine for Wiseco rings.
Offline Medyo Bastos
  • Gusto mo titi ko?
    • project
« Reply #2 on: April 27, 2020, 04:57:25 PM »
Does wiseco recommend you measure 1” up from the bottom?
Offline david 750f
  • 1976 CB750F
« Reply #3 on: April 27, 2020, 05:18:23 PM »
Thanks Hondaman :)
Medyo Bastos, I just checked one inch down from the top and got .014 and .020. I thought it was recommended (I've been wrong many times before) to check from the bottom.
1976 CB 750F
« Reply #4 on: April 30, 2020, 05:51:58 PM »
Thanks Hondaman :)
If using old bores (not a new overhaul) it is best to measure them near the bottom, because that will be the smallest bore size.
