Author Topic: Felt washer on carb slide actuator pivot arm ? Lost one  (Read 682 times)
Offline XC204
« on: April 27, 2020, 06:30:11 PM »
Some how I lost one of the felt washers on the carb slide actuator lever are  they available or an alternative or make my own? Thought about. An O ring that is not too tight nor loose.
Thanks
Gary
Offline my name is nobody
  • I like Pontiacs and Hondas
Re: Felt washer on carb slide actuator pivot arm ? Lost one
« Reply #1 on: April 27, 2020, 07:39:09 PM »
Put an ad in the "wanted" section. Someone probably has one from a junk carb
Offline SF
  • I burn gas very well
« Reply #2 on: April 27, 2020, 07:40:29 PM »
The felt washers hold oil to lubricate. Get some punches and order a sample bag of SAE F-1 industrial felt and make your own or some one can chime in with alternatives
92 wr250 sold
98 zx6r sold
04 zx10r
73 cb350 twin
75 cb550f
75 cb550f
72 r5c
rgid springer bobber project
Offline XC204
« Reply #3 on: April 28, 2020, 04:16:00 AM »
Thanks guys
Gary
Offline Machine1
« Reply #4 on: August 30, 2020, 08:03:38 PM »
I recently replaced all 4 of my felt washers with some made from a gentleman who makes them from this site: www.dudesgarage.com/
They are a bit of a tight fit, so I just used a little bit of bearing grease on the inside of the felts to get things moving well.  also had to vacuum sync again - but let me tell you, my bike has never run so well and so tight.  I’m running a 550 with a cognito moto air box filter.  It idles like a kitten.
