Author Topic: Honda CB400F, 1975, Torque specs  (Read 711 times)
Offline sindrenv
  • Student living in Trondheim, Norway. Honda CB400f.
« on: May 02, 2020, 06:44:47 AM »
Does anybody have a list of different torque specs for the Honda CB400F engine? I find only really barebones one, which doesn't have what i need. More specifically i am searching for the torque specs for the breather cover bolts and the rocker tappet covers.
Re: Honda CB400F, 1975, Torque specs
« Reply #1 on: May 02, 2020, 08:32:28 AM »
You dont do those to a torque unless you are good at helicoiling, just snug is good.
All the torques are in the genuine Honda manual
Offline Kevin D
  • SE Michigan
« Reply #2 on: May 04, 2020, 09:29:09 AM »
sindrenv, you will want to have a decent torque wrench when you get to your new head gasket.
Probably 3/8" drive, accurate in the range of 15 ft-lb. to 20 ft-lb.
I didn't find a torque value for the 400 head, but I did find heavy-duty head studs for your 400.
While I can't speak to the 400, I know that many use the HD studs on 750.
71 CB750 K1
104,000 miles
Original Owner
———past———
70 SL100/125/150
70 Candy BlueGreen CB 750 K0
« Reply #3 on: May 04, 2020, 11:10:33 AM »
Head torque is in the Honda manual
Offline trigger
  • Engines built on reputation, not advertising.
« Reply #4 on: May 04, 2020, 05:17:25 PM »
As Bryan said, they just need a nip. There is a torque setting for those bolts but alloy threads get weak over time and strip.
Head stud bolts are 16ftlb. After you have torqued it down, leave for 24 hours and re torque. After market head gaskets are thicker than the OEM ones and compact down more  ;)
Offline sindrenv
« Reply #5 on: May 06, 2020, 02:32:21 PM »
Thanks guys ;D
