Author Topic: Preventing further rust  (Read 1543 times)
Offline The Lone Builder
  • "Still running against the wind"
    • Belfast-2-Belfast-By-Bike
« on: May 05, 2020, 06:08:57 AM »
In the meantime .... I’ve started restoring the CB400F2 I picked up a couple of years ago. Like I said at the time, she is rusty - now there’s a good name!  :D
I’ve removed various parts and, using vinegar and a scotch pad removed a lot of the surface rust. Apart from some holes  ;D in the rear fender, all the parts are quite solid. I don’t have time or funds to get it all rechromed, so I want to use them as are. I’ve thought of painting them, but this too is a time consuming procedure and would prob not be much cheaper in the end. Oh, and I need to do the rims as well.
So I’m looking for a way to prevent or at least slow considerably, the flash rusting that occurs once they are dried off. WD40 Keeps it at bay for a while, but I guess that wold just wash off in the first rain.
So does anyone have any tricks for keeping these looking ... presentable is not quite the right word, but you know what I mean.
CB750 K2 - From Belfast-2-Belfast
CB750 K1 - The less, said the better!
CB450 K1 - Stalled.
CB400F Supersport - Not Rusty any more!
Follow my journey through Africa @ http://Belfast2BelfastByBike.com
Offline calj737
  • I refuse...
Re: Preventing further rust
« Reply #1 on: May 05, 2020, 06:46:08 AM »
Spray them down with CRC SP350. Leaves a decent protective film and you can spray them periodically. I use it on my fab table often.
« Reply #2 on: May 05, 2020, 06:47:15 AM »
She is Rusty!   You present a good question but unfortunately, I do not have an answer for you.
In my part of the world, replacement parts would be sourced for reasonable cost and those tossed in the bin.
But that is not the case for you.  Seems blasting and powdercoat would be your best best if you can have it done at a reasonable cost?
Offline disco
« Reply #3 on: May 06, 2020, 11:11:47 PM »
This works well for me and can be painted over.
1976 CB750 K6 Sapphire Blue
1972 CB750 K2 Candy Red
1972 CB750 K2 Candy Gold'
Offline flatlander
« Reply #4 on: May 06, 2020, 11:28:20 PM »
tectyl has a transparent spray that leaves a very strong, durable protective layer on the surface. it can protect even from salt corrosion and such.
having said that... you may be paying more for the rust protection than those things are still worth  ;D
Offline Doobie
« Reply #5 on: May 07, 2020, 04:21:34 AM »
I think paint is the only answer, but Silkolene and other companies make spray protectants that might work.
You only go around once in life so it might as well be on a motorcycle.
CB550K4
CB750K2
CB750K2
CB750K6
CB750K6
CB750K7
CB750F3
CB900F2
Offline Alan F.
« Reply #6 on: May 07, 2020, 09:34:37 AM »
What kind of finish quality are you looking for?
I want to recommend a vinegar soak to remove the rust, scrub lightly with scotch brite or a plastic brush no need to exert yourself, then a quick rinse spray of distilled water, then place them directly into a DIY zinc plating bath. You don't need to get all of the chrome off, the loose stuff will fall off though. With clean rust free steel the zinc plating will bond well and will protect from further rusting. The finish will polish up but will dull quickly out in the elements.
No need for expensive DIY plating kits, it can be accomplished sufficiently with commonly available items very cheaply resulting in a fairly durable finish.
Shoot me a PM if you need more info.
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #7 on: May 07, 2020, 09:39:42 AM »
for areas not seen such as the inside of fenders, rims and the frame brush on POR 15.
1973 CB 750 K3
10/72 build Z1 Kawasaki
« Reply #8 on: May 07, 2020, 06:30:40 PM »
Duct tape. Both sides...even comes in colors.
"Rusty" is a perfect fit! :)
Offline Spanner 1
« Reply #9 on: May 07, 2020, 06:55:36 PM »
Move out of Belfast, rust capitol of the world to the mountains of Spain, driest place on earth !.. lol.
« Reply #10 on: May 08, 2020, 07:07:24 AM »
Funny you should say that HM.  I have a small work cart in the garage that I picked up for free, was sitting outside for quite some time and rusty, so I wrapped the frame in duct tape!
« Reply #11 on: May 11, 2020, 03:58:22 AM »
Thanks all for the helpful, as well as the not-so-helpful, suggestions; I was actually thinking of the hills in SW France, Spanner. Would the duct tape go clockwise along the rims, Mark, or should I to wrap it round and round over the tyres too.
The last pic I posted is after treatment with vinegar and scotch pad. They are still not looking too bad a week later after a spray with WD40, but I don’t think that’d be too good in the rain. I checked out the CPC350, and the same guys, https://uk.rs-online.com/web/p/rust-corrosion-inhibitors/8232536/ in the UK, do another product CRC SP400 which is billed as a long-term protector so I might try that.
In the end I thought painting might be the best option, though I’m none-too-sure how it’ll look. So I’ve got a hole repair kit from Isopon and some rust treatment and paint from Hammerite. I’m going to try a small part first - maybe the brake pedal - and see how it goes.
CB450 K1 - Stalled.
« Reply #12 on: January 19, 2024, 01:39:55 PM »
Although this post is a bit old, I thought I'd just post a few pics to show what the end result was.
First is the rear mudguard (fender) which was repaired using Isopon and then sprayed in my cardboard paint cabinet.
The other, more solid, chrome parts I decided to powder coat; the result was clearly not concours, but looks good enough from a few feet away.
CB450 K1 - Stalled.
Offline Tim2005
« Reply #13 on: January 19, 2024, 02:09:10 PM »
Nice work, that came out well
Offline grcamna2
« Reply #14 on: January 19, 2024, 03:03:17 PM »
Yes it did  8)
Offline BenelliSEI
  • 1969 cb750
« Reply #15 on: January 19, 2024, 04:50:55 PM »
+. Nice!
« Reply #16 on: January 19, 2024, 06:32:42 PM »
Nice recovery!
