Author Topic: hose routing question  (Read 485 times)
Offline motofun
« on: May 05, 2020, 02:13:10 PM »
I'm restoring a cb400f that I rescued from the junk heap.   I'm about 90 percent complete but stumped on the hose routing.   Where does the hose from the top of the valve cover go?  Also does there need to be a hose from the bottom of the air inlet manifold or does it just get capped?
Offline 05c50
  • 05c50
    • Classic Motorcycle Solution
Re: hose routing question
« Reply #1 on: May 05, 2020, 04:28:04 PM »
The breather hose from the valve cover goes to the canister under the air cleaner housing. The hose from the chamber is open, but the hose from the canister is capped.
......Paul
Offline Bodi
« Reply #2 on: May 05, 2020, 04:31:25 PM »
Check a parts fiche. The top breather hose goes to an oil separator thing in and under the filter housing airbox, this lets the vented gas/smoke/whatever get sent into the engine and burnt with most of the oil and water included separated out and drained. There's a sheet metal bit spotwelded into the bottom of the filter housing where a plastic foam separator element would go, also should be a cover for that and a round thing screwed on under the filter housing: the tubes connect there.
There are around 7 parts for the whole unit, some inside the airbox and some outside. Some are NLA.
It is common to just get a longer piece of hose and just route it so the engine vents behind the engine by the swingarm pivot. Filters are available as well that look like miniature carb pods if you're afraid of getting crud sucked into the engine.
If you have the parts, you should use the separator and reduce pollution. If it's been removed then probably don't worry about it.
I haven't had an air inlet manifold for maybe 40 years (pods) but I don't remember a drain. This manifold is the rubber bit with a big hole to the airbox and four smaller holes to the carbs? If it does have a drain nipple, it should get a pinched drain tube - these let water (fuel?) drip out but don't let air in. That manifold has filtered air. I think the amount of dirt that could get in a small hose nipple is not worth worrying about and you can just leave it open. Plugging it would not be so good in my opinion, it's there to drain something.
« Last Edit: May 05, 2020, 04:32:59 PM by Bodi »
Offline motofun
« Reply #3 on: May 06, 2020, 11:43:56 AM »
Thanks for the help.  Most of my newer bike shop manuals have hose and wire routing diagrams but my CB400F manuals don't these.
