Author Topic: CB750K1 "Keep on the road"  (Read 5090 times)
Offline chiefum
Re: CB750K1 "Keep on the road"
« Reply #25 on: July 26, 2020, 07:55:01 PM »
Very good looking bike and nice work. I am aspiring to get my '73 project into similar shape, will try.
Thank you! It's a great learning experience working on these old bikes. The forum is also very helpful.
Offline chiefum
« Reply #26 on: May 02, 2021, 02:57:16 PM »
The side stand was bent and missing the nut, I found a replacement on Ebay and swapped them out.
Sent from my SM-N950U using Tapatalk
« Last Edit: May 03, 2021, 04:22:55 AM by chiefum »
Offline chiefum
« Reply #27 on: May 02, 2021, 03:06:02 PM »
Over the winter I had Hondaman rebuild the swing arm and swap out the shock bushings. Also replaced the old shocks with some ikons.
« Last Edit: May 03, 2021, 04:23:15 AM by chiefum »
Offline BenelliSEI
  • 1969 cb750
« Reply #28 on: May 07, 2021, 05:38:17 AM »
Your posts got me working on my K1 yesterday. Fired right up and as soon as it gets a bit warmer, will take it out. Your comments got me checking swing arm play. Mine still seems fine. I knock out the Honda lubricators on my swing arm through bolts, then drill and tap them for proper grease nipples. Pumped in some fresh grease.
Offline chiefum
« Reply #29 on: May 07, 2021, 05:55:57 AM »
Nice!! I think my rear shocks were shot, as the ride has much improved. I have new progressive front springs, but I haven't had the time to swap those out yet. It's much nicer having the zerk fittings.
Offline MauiK3
  • A K3 is saved
  • Old guy
« Reply #30 on: May 07, 2021, 09:03:25 AM »
Very nice K1.
I had to dress my brake caliper pucks on the sides to keep them from sticking.
Nice work.
1973 CB 750 K3
10/72 build Z1 Kawasaki
Offline chiefum
« Reply #31 on: May 07, 2021, 09:46:59 AM »
Very nice K1.
Nice work.
Thank you!
Offline BenelliSEI
  • 1969 cb750
« Reply #32 on: May 07, 2021, 06:25:15 PM »
I got some Progressive springs from vintagecb750 that cost so little I couldn’t resist. They were on sale a few years ago. Nice improvement and easy fit.
Offline chiefum
« Reply #33 on: May 07, 2021, 06:31:46 PM »
Nice! I'll probably go with tapered head bearing and replace my fork seals when I change my springs.
Offline Shtonecb500
    • Youtube profile
« Reply #34 on: May 07, 2021, 08:21:52 PM »
Nice project, you are making me want to do all the little things now...spend more money.
73/74'' CB500/550 resto-mod - sold
75' 750f 91' cbr f2 swap cafe - mock up
74' 750 chopper hardtail - complete - sold
74' CB750/836kit - Black mix & match - daily rider - always tweaking
71' cb500 K0 survivor - complete
71' K1 - CANDY GOLD/BROWN Winton kit - in process
Offline chiefum
« Reply #35 on: May 07, 2021, 08:28:48 PM »
Thanks! It's a good way to relax for me and also a good learning process. I hear you on the money part though.
Offline chiefum
« Reply #36 on: June 20, 2021, 03:36:03 PM »
Put new wheel bearings in the front Lester wheels I bought a while back.
« Last Edit: July 03, 2021, 05:09:34 PM by chiefum »
Offline chiefum
« Reply #37 on: June 20, 2021, 03:41:21 PM »
Sourced some rear wheel parts for the Lester wheels, as I want to keep my original stock wheels together if I want to swap back quickly.
Offline chiefum
« Reply #38 on: June 20, 2021, 03:48:34 PM »
Swapped out my k1 seat latch for a later model, thanks to Frank for sending the needed parts. Found this seat on Ebay and the seller was willing to ship from Italy. Thanks to Sean for the tire recommendations,  the Avon road rider mk2 are great so far.
Offline chiefum
« Reply #39 on: July 05, 2021, 07:30:38 PM »
I installed the new headlight and led bulb today. The led was stuck in customs for quite a while.  I'll have to see how it does in the dark.
