Picked up that bike this afternoon! Got it home and it's definitely missing a few things.
I noticed it's missing:
An ignition coil
Headlight bucket
Battery strap
Side covers
Rubber airbox boot
Key
Among other things here and there
I'm surprised that it has:
A decent set of points with little wear
Original (or at least Honda) exhaust
Original seat pan with an aftermarket cover job
A completely shiny rust free tank
All the cables intact although the front brake cable is seized
The engine is definitely seized. The kick starter is stuck down and won't come up but will move down a little. Just won't turn the engine. I think the cylinder is just stuck at the top of it's stroke. Valves look okay and I squirted a bunch of oil in the valve cover and on the guides as well as filled the cylinder with PB blaster.
Fortunately the carb isn't stuck and the throttle slide and choke plate move great. I'm excited to tear in to it tomorrow.
Also the front and rear suspension feel great. No leaks in the forks surprisingly.
Sent from my LG-G710 using Tapatalk
