Author Topic: CB550 Top end rebuild  (Read 649 times)
Offline crantonr
« on: May 09, 2020, 08:50:17 AM »
Hi All,
In the process of stripping back the top end of my K3 CB550. Not going too badly until I encountered a bent inlet valve on #1 cyl which probably explains the power loss problems I was getting. Will the guide need replacing as well or might it still be OK? Also I noticed that some of the large valve springs had 2x shims under them. Is this to compensate for weak springs or do you think the PO couldn't count?
Richard
Re: CB550 Top end rebuild
« Reply #1 on: May 09, 2020, 12:42:34 PM »
I think the PO was a moron, there is a warning on how to fit the cam cover without bending valves in the manual and excess shims is just carelessness!
Insect the guide carefully for cracks/breaks and see what play there is with new valve
Offline calj737
  • I refuse...
« Reply #2 on: May 09, 2020, 02:43:48 PM »
Replacing a valve alone does not require a new guide. If you replace the guide, you must recut the seat.
Offline crantonr
« Reply #3 on: May 09, 2020, 11:43:44 PM »
OK thanks guys
