Just putting this up here so that perhaps the next time this problem happens to some other noob he will do a search and find this post.
I've been slowly working on the restoration of this 74 CB550:
![](https://photos.smugmug.com/1974-Honda-CB550/i-vdvqn85/0/e795e199/M/IMG_0974_heic-M.jpg)
A good friend did the paint job on the tank and side covers. The inside of the tank is in good shape.
I haven't ridden her too much since the tank was painted, but the other day I took her out far enough to run her down to the reserve tank. Once she was on reserve she ran very poorly until I filled up the tank at the closest gas station. If felt like there wasn't enough fuel getting to the carbs to keep them all happy. Once filled and switched back to to the "on" position on the petcock she ran fine.
This particular bike has this type of petcock:
![](https://cdn1.bigcommerce.com/server5200/jcd9tbp/products/1583/images/6056/genuine_honda_petcock_16950_300_020_CB500_CB550_CB750_fuel_valve_tank_gas_on_off_reserve_stock_outlet_dual_two_1__94143.1394238023.1280.1280.jpg?c=2)
..when the petcock is set to reserve, fuel enters the petcock bowl through the gap between the copper tube of the petcock and the center hole drilled through the bottom of the fuel tank, shown here:
![](https://photos.smugmug.com/1974-Honda-CB550/i-ZXrbMhQ/0/d544b666/L/CB550%20tank%203%20hole%20petcock%20mount-L.jpg)
If there is gunk or paint remnants in that hole it will slow down the flow of fuel when the bike is on reserve. That's what happened to me.
When I got home from that ride I tested the fuel flow on both main and reserve settings of the petcock. Fuel flow through the main circuit was fine, fuel flow through the reserve circuit was a dribble. It was enough to keep me going at about 25 mph for my 6 mile ride to the nearest gas station.
I fixed the problem by scraping the excess paint out of the center hole of the petcock mount and re installing the petcock. Now I have good fuel flow on both the main and reserve petcock settings!
Anyway I hope this doesn't happen to any of you but if it does perhaps you'll find this post helpful.
