Author Topic: '77 CB750F Oil pump gaskets and seal  (Read 584 times)
Offline Niels Bull
« on: May 13, 2020, 02:27:11 PM »
Anyone know who sell complete set of gaskets for the oilpump on a '77 CB750F ? seems not to be a problem getting the various o-ring seals, however the OIL SEAL, LEAK STOPPER part #15166-300-000 seems to be an issue - not even sure if it need to be replace when rebuilding but figured it wouldn't hurt.
regards Niels
Offline hammerspace
  • when the house is rockin don't bother knockin
Re: '77 CB750F Oil pump gaskets and seal
« Reply #1 on: May 13, 2020, 04:23:34 PM »
https://www.ebay.com/itm/162442240391
Hope this helps!
Sent from my Mi A2 using Tapatalk
- '78 CB750 F3
« Reply #2 on: May 13, 2020, 05:26:16 PM »
Hope this helps!
If you get this kit: don't use the springs. The last one of these that I got had too-strong springs in them. The rest of it was OK.
The oil pump's paper gasket comes in almost every gasket kit today.
You can also contact Elan (if he still picks up his PMs?) as he made the first versions of these kits, with the stopper and a correct spring, but without the O-rings (2.4x15 or 2.5x15 size) and all the other stuff - which you are likely to not need!
Offline Niels Bull
« Reply #3 on: May 14, 2020, 04:29:03 AM »
thanks for the input - looks like it's all in that set :-)
