Author Topic: Exhaust Studs?  (Read 1123 times)
Offline The Gurg
Exhaust Studs?
« on: May 15, 2020, 08:24:08 AM »
Read through some exhaust stud conversion posts and not readily seeing the answer for standard K models: Anyone know the correct stud length for converting to exhaust studs on a CB750K5? I have an aftermarket 4 into 2 exhaust, but using the original flanges.
Do I need washers? Or are M8 flanged nuts good?
Does the grade of SS matter?
Offline The Gurg
Re: Exhaust Studs?
« Reply #1 on: May 15, 2020, 08:36:32 AM »
Reading that 8x32 (Part No.  92900-08032-0E) was used for the F models starting in 75. F models don’t have the flange that K models do. So guessing 32mm isn’t right.
Seeing that someone used 40mm on a K model, but it’s a shade short (see link below). Maybe 45mm would be right or 50mm?
http://forums.sohc4.net/index.php?topic=163097.0
« Last Edit: May 15, 2020, 10:02:01 AM by The Gurg »
Offline The Gurg
Re: Exhaust Studs?
« Reply #2 on: May 15, 2020, 10:05:53 AM »
Thanks CalJ737!
Seeing the recommendation is not to double nut to tighten. Guessing I finger tighten the stud then torque the nut. Anyone know torque specs on SS 8mm?
Offline mrbreeze
  • Not your average
Re: Exhaust Studs?
« Reply #3 on: May 15, 2020, 10:51:34 AM »
I don't recall the length but if I remember correctly I used longer studs and cut them to the length I needed. Dress the end you cut off and screw them in so they don't look like sh!t. I got mine at a wrecking yard from a row of import cars. Intake manifold studs and flanged nuts.
MEMBER # 257
