Author Topic: Cb650 carbs  (Read 436 times)
Offline Bran2001
Cb650 carbs
« on: May 21, 2020, 12:24:09 PM »
Will the carbs off a 83 cb650 fit on a 82 cb660
Offline fizzlebottom
Re: Cb650 carbs
« Reply #1 on: May 21, 2020, 01:03:19 PM »
1982 was the last 650 SOHC motor, and 1983 was the first 650 DOHC motor. Both came with Keihin CV carbs, but completely different models. The big hurdle would probably be carb spacing differences between the two models. If they aren't exactly the same then you'll have to figure out some custom carb insulator solution and a custom airbox.
1982 CB650SC Nighthawk
Offline Bran2001
Re: Cb650 carbs
« Reply #2 on: May 21, 2020, 01:13:11 PM »
Alright thanks
