Author Topic: Replaced starter solenoid, now only getting spark on cylinder 1??  (Read 962 times)
Offline dunnp2
Hey guys, need some help diagnosing this one. My '77 CB550 was running and happy yesterday, and this morning I replaced the starter solenoid. Starter cranks the engine strong now! Except somehow now I'm only getting spark on cylinder #1. What did I screw up?
-I've tried removing the solenoid and kick starting with just the battery connected to the power wire.
-The spark plugs look fine.
-I'm checking with a timing light. Totally normal flashes on #1 with kick or starter, nothing at all on 2/3/4.
-I'd suspect a coil or a wire if 4 was firing...
-Battery is fully charged.
-With the starter assist, it tries running on just #1 but doesn't quite have the power to keep going.
It does smell like gas on the plugs, but I didn't crank long enough to get much gas in there. I don't think it's flooded, but what's the best way to clear a flooded engine? Run the starter with the plugs out?
Anything else I can check? The biggest mystery (I think) is why 1 is firing but not 4.
Offline dunnp2
Re: Replaced starter solenoid, now only getting spark on cylinder 1??
« Reply #1 on: May 23, 2020, 06:45:19 PM »
Oh, I forgot to mention that I have a dyna S ignition.
« Reply #2 on: May 23, 2020, 10:36:58 PM »
Dyna gone bad
Offline dunnp2
« Reply #3 on: May 24, 2020, 10:24:00 PM »
Isn't that typically only when hot? I haven't had any issues until now...
Also shouldn't cylinder 4 be firing if the Dyna is bad?
« Reply #4 on: May 24, 2020, 10:45:09 PM »
If you only get a spark on one plug of a coil the other plug or cap is duff
Offline dunnp2
« Reply #5 on: May 27, 2020, 10:41:38 PM »
Yep, it was the plugs, 3 fouled all at once! They were all covered in soot. Torched them clean, fired with the starter in half a second. Amazing. And yes, I'll be replacing the plugs I cleaned with a torch  :)
