Author Topic: 1975cb400f crankshaft issue  (Read 538 times)
Offline hawaiikid
  • 1975cb400f
« on: May 24, 2020, 07:00:50 PM »
While trying to slip my pistons into cylinders i noticed my crankshaft. will only spin in one direction. Not sure if that is normal or not. Was wondering if that is normal and if not how do i rectify the problem would sure like to hear from other more experienced members. this is my first time to disassemble and rebuild a SOHC four. when i push down on the kickstart lever it will move in the normal direction but not the opposite.
Offline ttr400
    • ttr400 Projects and Billet parts.
Re: 1975cb400f crankshaft issue
« Reply #1 on: May 24, 2020, 10:14:19 PM »
It should be able to turn in both directions. check that the cam chain is not jammed up on the crank sprocket.
Kevin
CB400F- 492 Yoshi Racer.
Cb400F- 466 Yoshi Cafe.
CR750 D Mann Replica.
VFR750R- RC30 - 1988.
www.ttr400.com
Offline Bodi
« Reply #2 on: May 25, 2020, 10:15:25 AM »
If the starter motor is installed it will make turning the crank "backwards" very difficult.
