Support the site. Your contributions keep this site running.
are you implying that your next build will follow a whiskey bar theme?
Lectron carbs came with clear bowls..
Great post! However, I prefer to fill my rocks glasses with this:
I remember working on an automobile carburetor once and noticed that it had a round inspection window built into the bowl.That would be a nice thing to have had on many carbs.
When working on carbs in a vice like that, do you have to use gas, or can you use water, as long as it dries out before reinstalling on the bike?
Quote from: flatlander on May 26, 2020, 11:44:40 AMare you implying that your next build will follow a whiskey bar theme? Not a bad idea. Maybe I can get Noddy78 to do some wood finishing, haha
Quote from: DaveBarbier on May 26, 2020, 12:26:11 PMQuote from: flatlander on May 26, 2020, 11:44:40 AMare you implying that your next build will follow a whiskey bar theme? Not a bad idea. Maybe I can get Noddy78 to do some wood finishing, hahaHow about a tap on a bar made from a carburetor body
Quote from: grcamna2 on May 27, 2020, 02:16:12 PMQuote from: DaveBarbier on May 26, 2020, 12:26:11 PMQuote from: flatlander on May 26, 2020, 11:44:40 AMare you implying that your next build will follow a whiskey bar theme? Not a bad idea. Maybe I can get Noddy78 to do some wood finishing, hahaHow about a tap on a bar made from a carburetor body Now you’re thinking! I want to go to a bar and when I need a refill I’ll say that my float height needs adjusting, haha.But seriously, I need to find a sohc4 inspired bar.
Quote from: WhyNot2 on May 27, 2020, 10:03:39 AMWhen working on carbs in a vice like that, do you have to use gas, or can you use water, as long as it dries out before reinstalling on the bike?As rotortiller said, the specific gravity is different so you need to use gas. The floats will float higher or lower in fluids with different specific gravities.
