Author Topic: Starter Issues  (Read 906 times)
Offline knowsnothing
Starter Issues
« on: May 27, 2020, 01:00:50 PM »
Hi All,
I am so close to getting a running bike, 78 cb750k, after 10+ years  I can taste it.  Then all of a sudden I stared having a starter problem and I can't seem to figure out what the issue is.  I am going to try to attach a short example video.
When I press the start button, starter begins to work, then sounds like it disconnects? and just spins freely.  I have check the starter gear install, gear/washer/rod all look good.  Even replaced them with ones i had from another engine.   Everything looks as it should to me.  The teeth on the starter themselves also look fine to me, no chips/missing teeth.
This a fresh engine rebuild. 811cc, ported head and has run for a short time before i started chasing problems.  Any ideas would be much appreciated.
1978 CB750k Blue - for sale
Re: Starter Issues
« Reply #1 on: May 27, 2020, 01:22:33 PM »
Starter clutch on back of generator rotor, you may get away with new rollers, pins and springs. Sometimes need new clutch bodyand large gear
Re: Starter Issues
« Reply #2 on: May 27, 2020, 01:41:31 PM »
Oh boy, ok so big bolt out, rotor off, i can get to everything?
Thank you bryan
Offline MauiK3
  • A K3 is saved
  • Old guy
Re: Starter Issues
« Reply #3 on: May 27, 2020, 03:12:03 PM »
You may need the tool to get the rotor off.
1973 CB 750 K3
10/72 build Z1 Kawasaki
Re: Starter Issues
« Reply #4 on: May 27, 2020, 03:43:31 PM »
Good to know, thanks
Re: Starter Issues
« Reply #5 on: May 27, 2020, 03:46:01 PM »
 As the guys said its your starter clutch. I'm curious as to what brand your 811 kit is. Wiseco used to make a nice 811 with 10.5 compression. Friend had one and it ran very well.Think its been discontinued for a long time.
Re: Starter Issues
« Reply #6 on: May 27, 2020, 04:26:16 PM »
It was an old yoshi kit i picked up here 5-6 years ago.  Came in the boxes and everything
Re: Starter Issues
« Reply #7 on: May 27, 2020, 05:02:37 PM »
The usual culprit is the hub of the big gear. Check it closely for wear, as well as the rollers. Also, make sure the rotor bolt is tight; the only thing locking the rotor to the crank is the taper, and if loose the rotor can spin on the crank.
Re: Starter Issues
« Reply #8 on: May 27, 2020, 10:50:37 PM »
I have "found" the kit i knew i had that somebody wanted a long time back.
It is a nos big gear, clutch ass, rollers and pins but i lost the springs, as i dont work on 750's any more its up for grobs at a reasonable price plus postage from UK
