Author Topic: 1977 CB550K Oil Pump Cover O-Ring size?  (Read 1333 times)
Offline Maraakate
« on: May 28, 2020, 02:30:53 PM »
I noticed some drip on the left side of my 77 CB550K awhile ago and thought it was the shifter seal.  When I took the cover off I found out that it was the bottom on the oil pump cover.  I verified this by cleaning everything up and starting the bike and you can see a slow drip coming from this.  The book said to replace it with a 47mm o-ring.  I thought this was the same part number as the o-ring that goes from the pump to the case, PN#: 91302-250-010, but it's not.  It looks like its a few millimeters too big.  I am also unsure if its supposed to be a square o-ring or if the old o-ring is just malformed from being so old.
Has anyone replaced this o-ring?  If yes, what are the dimensions?  Is it something I can take over to NAPA and have them match it up?  Is it a square or round o-ring?
Attached is a picture of the cover, highlighted in yellow.
Thanks!
1977 CB550K
1979 CM400A
Offline Maraakate
Re: 1977 CB550K Oil Pump Cover O-Ring size?
« Reply #1 on: May 28, 2020, 09:28:13 PM »
It appears I may have answered my own question.  An older thread mentions part number 91305-426-003 originally for a GL1000 should work.  I will give the dealership a call tomorrow and once installed I will update if this is the right part.
1977 CB550K
1979 CM400A
« Reply #2 on: May 28, 2020, 10:44:33 PM »
Yes it will work, 46x2 O ring.
Undo the cover screws with pump on engine using an impact driver
Offline trigger
  • Engines built on reputation, not advertising.
« Reply #4 on: May 29, 2020, 01:10:00 AM »
Yup, but that kit is in the UK i know the seller who is super helpfull but you are still dealing with international postage so maybe easier to go the Honda dealer way even if not a lot cheaper
Offline DaveBarbier
« Reply #5 on: May 29, 2020, 04:46:17 AM »
Contact member Elan. He puts together and sells oil pump rebuild kits with all o-rings included. Here’s a link to the whole kit but I bet he can send you just that one. But, maybe not a bad idea to have the whole kit in case the other seals go bad.
https://www.ebay.com/itm/163309915351
Offline Maraakate
« Reply #6 on: May 29, 2020, 04:57:50 AM »
I already have the larger o-ring that goes to the pump to base and I also ordered the two smaller o-rings as well, but I am waiting for them to show up from partszilla (I learned really quickly my local dealer has better prices than partszilla oh well!).
@BryanJ: Yes, when I got the wrong o-ring I learned quickly that you must use the impact driver to get the cover off.  Thanks for mentioning it though.
« Last Edit: May 29, 2020, 05:50:24 AM by Maraakate »
1977 CB550K
1979 CM400A
Offline Maraakate
« Reply #7 on: May 29, 2020, 05:44:22 AM »
Also, I see that both kits have the o-ring for the pressure relief valve.  Of course this is also a part that doesn't show up on the microfiche.  I can replace this too if someone has a part number for me.  Is there anything special I need to know about disassembling the relief valve?  I already have the two o-rings for the collars on their way.
I'm more of a "don't fix it if it ain't broke" kind of person.  However, I do understand that by replacing the o-ring on the cover the leak may move to another seal on this pump.  I'm OK with doing the o-rings that go to the case as I believe that should be easy to remove without many repercussions.  It's that relief valve that I am concerned about.  Especially when I have never done it before.
1977 CB550K
1979 CM400A
« Reply #8 on: May 29, 2020, 12:57:38 PM »
In 40 odd years i never took a relief vavle cap off, leave it allone.
Offline Maraakate
« Reply #9 on: May 29, 2020, 01:02:00 PM »
I agree.  I will just do the outer cover, verify it is no longer leaking, check it again in a week and if new leaks appear in the back or from the pressure relief valve then I will follow up.  I don't like to disturb things that are not broken.  Especially o-rings/gaskets.  I've found as you've put a good few hundred miles on some old mystery bike (like mine, and it's been over 3000 miles now) the leaks that need fixed will show up, others you thought were an issue may disappear.  When you disturb things is when that seal is broken and now it must be replaced.
1977 CB550K
1979 CM400A
Offline trigger
« Reply #10 on: May 29, 2020, 04:31:50 PM »
Julie sends those upgraded kits out worldwide at a postage cost of £2.90 mate  ;)
« Reply #11 on: May 29, 2020, 11:12:22 PM »
Not the cost Trigger, seems from other comments that international mail into US is being held up at moment. Julie stocks a lot of good stuff and service is excellant but post offices are not good at present. I read that Japan post has sent nothing out at all for a while.
Offline trigger
« Reply #12 on: May 30, 2020, 12:56:11 AM »
I have not had any problems with post in or out. Packages get to Australia, New Zealand and the States quicker than any of the Scandinavian countries but, that has always been the case for some strange reason . My Yamiya orders have been coming through with UPS in less than a week to my door for the past 2 months.
Offline Maraakate
« Reply #13 on: June 04, 2020, 03:00:48 PM »
Got the o-ring today from the dealer.  Swapped out the old one with the new one and it appears all is well, but we'll find out after a few rides if it decides to weep out of the other ares on the pump :P
1977 CB550K
1979 CM400A
