Author Topic: 500 K0 Points WIring Sequence  (Read 528 times)
Offline cb
« on: May 29, 2020, 10:41:48 AM »
Before I fire up my engine (again), I would like to ask if I have the wiring to the points in the correct sequence.
Left: Nut, Green, Insulator, Blue
Right: Nut, Green, Insulator, Yellow
Is this correct, please?
Offline Deltarider
Re: 500 K0 Points WIring Sequence
« Reply #1 on: May 29, 2020, 11:05:21 AM »
The insulator should insulate, so goes on the inside. The sequence of blue (or yellow) and green is up to you. Just make sure the forked connectors do not accidentally contact the plates.
CB500K2-ED Excel black
Offline cb
« Reply #2 on: May 29, 2020, 11:14:21 AM »
Thank you for your quick reply.  I will go out and hook up some fuel again and give it a try.
« Reply #3 on: May 29, 2020, 12:44:27 PM »
Nut
Spring washer
Plain washer
Condenser lead
Yellow(or Blue)
Insulator washer
Fixed post
Indulator washer(should be top hat shaped to fit in hole of fixed post
Spring from contact set
Plain washer
Bolt head
Hope that helps
Basically the contact spring fitted to moving contact needs to electrically contact the condenser and wire to coil but not touch ground
