Author Topic: Cb750 K2 clutch lifter bolt torque... anyone know?  (Read 998 times)
Offline fxef79
« on: May 29, 2020, 04:36:26 PM »
It’s not in the shop manual. I have them just snug/bottomed out after getting all 4 tightened down equally without snapping the plate.  But I hesitate to put any additional torque to them beyond that.  If I snap another plate I’m likely to throw a tool through the wall.
Re: Cb750 K2 clutch lifter bolt torque... anyone know?
« Reply #1 on: May 29, 2020, 08:18:04 PM »
Snug is fine; they are only 6mm bolts. ;)
« Reply #2 on: May 30, 2020, 09:20:52 AM »
If you can't find the correct figure I say use the standard torque for a 6mm bolt. ~ 7lb or as Scottly says, snug
« Reply #3 on: May 30, 2020, 10:35:49 AM »
There is a general torque guideline in CB750 shop manual for different type of bolts, head type and dimension.
I also tighten these M6 7ft lbs.
Side covers less, around 6 ft lbs. Tighten again after a day when gasket has compressed.
Important to have a good tool for these small dimensions. 1/4" socket torque wrench.
