Author Topic: Well, it seems my bike is being a little bit of a drama queen, shifting, oil, sm  (Read 1718 times)
Offline LadyTano
So I've been checking oil like clockwork since I bought my bike. I've put 1700 miles on her since I did new oil change right after buying. Odometer is 25,000.
So I checked oil last night. Thin, but no gas smell. Darker than I'd like, but I figure it's just old oil crap from previous owner.
Today, headed to work, she's not wanting to shift into first. Second is fine. Kinda weird, but ok.
At red light, it won't shift at all, oil light flashes. I push her to side. Give things a poke. And seems fine. Shifts great, etc.
Jump on freeway, I get.. half mile? Power just disappears, oil flashes once, engine sputters and stops.
So now I'm on side of road waiting on fam to lend a hand.
I pulled the oil dipstick. Smoking a bit (not a ton, but still.....).
Oil level -seems- fine. I'm hoping I'm just misreading the oil.
But anyone care to venture a guess?
Any/all info or input is very welcome.
Thanks!
*Crossed fingers I didn't cook the motor*
Offline bear
  • Leeton in Australia
I'm no expert on autos but at a guess the clutch plates may have failed and the friction material from the plates could  have blocked the oil pump.
Good luck with it.
« Last Edit: June 04, 2020, 04:16:44 pm by bear »
Gas tank could be vapor locking due to cap not venting. Any number of issues. Going to have to be more descriptive in what it is doing now.
Offline LadyTano
Well, after a long day of wrenching and testing....
Engine seems to be seized. Starter just kinda whines, and I can't manually turn over the engine.
So.... Started tear down. Pipes removed, gastank pulled, spark plugs and such all pulled. Top cover removed (I thought those screws we're gonna break) but damn. All out.
As soon as I figure out parts needed, I'll order. And hit the other stuff she needs. New front pads (was gonna be this weekend's project), new sprockets/chain, rear fender, etc.
So, I'm thinking shipping times and such. She'll be down for a bit. But I'm luckily able to focus on her after work and weekends, so hopefully I'll have her running asap.
I keep seeing hondaman's book as recommended. Good buy I assume? Like I have the original service manual. But more info> less info.
Thanks yall! Pic added cause... Well. It's purdy (photographically speaking-its edited, not nearly that brown in real life).
Does one end of head appear less oiled than the other ? If so it could be topend.
Offline LadyTano
754- sadly no.....
So I spent a good chunk of today with my Dad pulling apart, carefully organizing parts, etc.
It seems the #3 cylinder (2nd from right -riders right) the piston arm bearing in the crankshaft is seized.
The cylinder at a (non gauged) look look damn good. Polished, no burrs or weird spots. The #3 has a little staining?  But smooth, and clean. Surprisingly so. Pistons seem decent. Hell, rings too.
It was apparent the #3 was burning oil. The valves had scaly looking oily deposits on them.
So next I gotta pull the upper part of the clamshell (if that's the right word....) Of the motor/transmission to check for other damage.
So far, other than the seals all being shot (of course), and the one bearing. Things are surprisingly good condition.
I guess my question is. Having never done engine work, but being incredibly handy. I know I need a full seal kit. I know I should find someone to spec the pistons, the crankshaft, the cam shaft (I think that's the term, I'm bad with words -the upper shaft), and replace the pistol arm bearings, and main bearings.
Is there anything I should hit/get checked by a pro that I'm missing?
Or any suggestions for where to get the items spec-ed? I'd prefer reasonably local (detroit-ish) but I'll drive a couple hours of the person is good and fast.
Pics as soon as I can modify to fit.....
I'm good with a wrench and mechanically inclined. But I know there's a few things I should get a pro for help so I keep her running as long as possible.
Offline bear
Have you had a chance to check if there is any contamination or blockage affecting either the oil pickup screen or the oil filter?
Brian
If the rod is seized , it usually is not to do with piston, it's lack of oil..
 Used cranks and rods are cheap, but you will usually have to fit new shell bearings.
Offline LadyTano
Bear- the filter looked pretty decent I think. Nothing seemed to be clogged in or around it. Other than the filter looking kinda beat- especially for being only 1,700 miles on it (I did K&N). I didn't see anything in the oil pickup screen. Or anything clogging.
754- So I did get everything pull down to the lowest level of the engine. I could see the pistons, rings, and the beginning of the crankshaft (the last seal is being a pain....) So not open all the way yet.
The #3 piston is very, very tight when moving/rocking  forward to back.  The others, move pretty freely. (Front to back of course).
So when I purchased, she had the tiniest of tick. Hardly noticeable, but on my list of to do's. It got noticably quieter the more I rode, and after I did oil, etc. I think it was a bearing going. Judging by the oil color when I did the first change, and the literally disintegrated filter.... I'm guessing the damage was already done. And any oil I did after buying was a bandaid at best.
I'm a little lost on bearing size to crankshaft wear. I read there's colors, but some advice said just do yellow... *Shrug*
I'm taking the camshaft, piston heads, cylinder block into a local place (my cousin recommended,-Detroit Iron) so get everything checked for the tolerances (I understand theory of this, but I'd rather a professional get the info so I don't mess it up). I'll be bringing the crankshaft in as soon as I have it pulled.
So is there a place y'all would recommend to get the seals, and parts in a quick (ish) manor? I want to replace every seal. I don't want to do this any time soon, and the seals have to be 43 years. I was do all fresh seals, and new bearings, piston rings if needed. I want to do this right, to have her last as long as possible.
Thank you all! I do very much appreciate everything you've tossed out. It's an amazing learning experience. If anyone happens to be Detroit (well surrounding area) and would be willing to help, I'll happily bribe with beer and bad jokes (and Irish music.... Radio, I can't play yet).
-Cassie
Offline LadyTano
I had a friend and local a machinist check the bored, pistons, etc.
Here's what we got:
Bore expected: 61.01 mm
Bore actual: 61.0616 mm (2.404")
Piston expected: 60.965mm
"What can I get away with?"
Piston 1 actual: 60.9727mm
Piston 2 actual: 60.9649mm
Piston 3 actual: 60.92mm
Piston 4 actual: 60.92mm
He thinks new pistons at 61mm would be best if I wish to keep the bike and keep working well (and I do, so ...)
I found some new-aftermsrket pistons on eBay for $120 (ish) shipped, with rings. Good reviews, etc.
My only question at the moment is:
Will this work? It's for a K, but... I know a lot of the parts are the same.
https://www.ebay.com/itm/174138579061
Thanks!
Offline MauiK3
  • A K3 is saved
  • Old guy
#1. Hondaman’s book will answer most of your questions as well as steer you clear of expensive mistakes.
#2. Look at the oil pump screen, it may tell you something.
#3. Since you are this far in, don’t cut corners.
#4. Most machine shops that do car work cannot properly help with these motors, use one of the experts here on the forum. I used Mark Paris ( Hondaman) for my head and cylinders. Perfect work.
1973 CB 750 K3
10/72 build Z1 Kawasaki
Offline LadyTano
1) that's the plan :)
2) as soon as I can see it I'll check. I'm wondering if it's blocked as well. It'd fit the old "sat a long time" kinda thing
3) imma trying. I found pistons that are right. I just don't want to wait for shipping from Japan.... During covid junk. But, if it's what's I gotta do ...
4)  so he's actually a machinist by trade. Motors are a side thing he enjoys. He knows a lot, but.... Not bikes so much. A lot of similar stuff between the two, but he did say to make sure I have solid info. He'd help, but it's beyond his area of expertise. .
I did just order a whole Athena seal kit, and am now ordering the book. :)
I thought I already ordered book, but I guess I didn't hit the pay part ...
Offline LadyTano
-jist- a quick poke, but the book info doesn't mention the auto series.
I know a lot is applicable, but is it still worth it? I know he pistons are different, crankshaft, etc. *shrug*
Offline MauiK3
  • A K3 is saved
  • Old guy
The book will help you with the motor in general, things like the head and cylinders.
Well worth it.
1973 CB 750 K3
 And the rest of the bikes, brakes, sprockets,  wheels, forks, electrics, carbs  , those sort of things.
   I think  the Clymer manuals that go to 1978 have auto info in them..
« Last Edit: June 10, 2020, 01:50:51 pm by 754 »
 I'm not big on shipping, but if you wanted to do a road trip I'd donate an A crankcase, trans and rotating assembly. Unknown condition but the price is right.  I removed the top end (head and Cylinders) for parts for another bike. I'm in Galesburg Illinois.
If you love it, set it free, if it stays it's probably one of my 750's.
Offline LadyTano
DonR- that's incredibly kind of you! I really appreciate the offer! I think (lord i hope) all is good now.
So long story short, she's getting buttoned up, hopefully today. And test fired. ^-^
So, new bearings, new crank, new rods, pistons, many screws, seals, etc.
It was a chore, but a local guy was helping me with the stuff I wasn't familiar with.
One pic for now. ;)
More to come.
Offline LadyTano
Update!
Alright. So buttoned up. She started a little sluggish (really not bad)
I did need to adjust the idler, she kept wanting to sputter.
The exhaust had a leak, so I doubled the gaskets.... Didn't help much. I think I'm gonna have to use some exhaust cement. :/
I accidently installed the shifter mechanism slightly off. So had to get that fixed (was kinda annoying, but hey, easy fix).
So next in my plate (tonight's project) additional rear lighting wiring. Reinstall saddle bags and wire up a plate light (or at least, gets wires run).
Should be easy. (I really need a good night's sleep, too many 3 am and work at 930 days)
Exhaust tomorrow after work. Install plate (putting on my saddle bags).
A local cb750 guy (a coworkers' Dad) said he would help with timing ignitor and carbs which is incredibly kind. I guess he's rebuilt a few. He's been a great resource for info on the fly.
I don't have a video of current start up and running, just the initial. As soon as I do, I'll post a link. But she sounds 10x better than she ever has. Little delay when opening throttle, but I'm guessing it's a carb thing- they still need some love -or outright replacement. Still deciding if I'd rather retrofit something better.
Anyway, pic!
Offline Randy Nevrotski
  • Randy
  • ITS AUTO-MAD-TIC
how is your bike running now. when i had problems with my carbs it took some time to figure them out. about six times i had them off. first working behind someone cleaning up there mess. the shop manual says to blow out all holes . that's not good enough . the slow jets are pressed in . i had to pull them out all 4. on top has little holes you have to clean out with a wire. make sure u put them back straight and tight. also why so many times carbs came off because i had to re jetting them . bigger jet read plugs remove carbs put next size jet then repeat
1976 CB750A & Other bikes 1980 KZ 650 cafe racer  81 CM400A 82 GS450 79 KZ650 84 NIGHTHAWK 700 77 KZ650 CAFE  87 ZX750R NINJA 2001 KATANA 600 1983 GPz 750 1980 CB750 CUSTOM Past bikes 1974 suzuki GT750 TRIPLE Care Free Custom chopper 117 motor 95 Honda XR650L Dual Sport 87 ZX600R NINJA Honda CB550FOUR 87 Yamaha 225 trike honda 250R trike RM80 HONDA TRAIL CT70
