Author Topic: 77' Cb750k -- CAN I UPGRADE TO 18" REAR WHEEL?  (Read 1794 times)
Offline Xander^
Re: 77' Cb750k -- CAN I UPGRADE TO 18" REAR WHEEL?
« Reply #25 on: July 19, 2020, 09:12:43 PM »
Yeah im thinking of keeping the original rear hub and purchasing a new 18" rim from 4into1 or vintage cb750 or something.. and then the appropriate length spokes for that connection to work...
what size dimensions should i go with? 18" x 2.15 ? i want to run a 130 wide tire at least.
1977 CB750K cafe
Offline mrbreeze
  • Not your average
« Reply #26 on: July 19, 2020, 11:32:38 PM »
I wouldn’t run a 130 on a stock 18” rim. I do believe it will fit but it is like the absolute largest size that will. The tire will wear bad and feel squirrelly in the turns. Stock is 110 (pizza cutter). I ran a 120 for awhile and it wore out the middle of the tread in no time. It like squared off and felt iffy in the turns. If you want a fatter tire you need a wider rim.
MEMBER # 257
