Hmmm, this carb has 1 on each side. Do i cap it off, or run 2 adjustment screws?
That's odd. Typically they only have one. Maybe the previous owner drilled and taped the other hole?
The CRs I have on my 750 only have one per carb. You'll have to investigate if that second air screw hole goes into the carb body. You can spray some carb cleaner or WD40 to see if it comes out the bypass port on the back side, the engine side of the carb.
The photo is carbs 3 and 4 on mine. The air screws are towards the outside of the carb. If the second screw hole on yours is on the inside, I would put a screw in it to just plug it.
Sent from my moto z3 using Tapatalk
