Author Topic: CB400F Engine swap due to poor compression?  (Read 1288 times)
Offline Alaxy Galaxy
« on: June 10, 2020, 01:49:33 PM »
I'm wondering if I should swap the motor in my CB400F.
The engine I've been running for 3 years was sold to me as a good runner. Although it's been reliable and has good power, it does leak a bit of oil and, more importantly, consumes oil due to poor compression.
I have a spare motor on the bench that I know nothing about other than it's not stuck, the cam-chain shoe is free and it has great compression (135 psi on all 4). My current motor barely has 90 psi with oil in the bores.
What would you do? I can swap everything over if need be. (magneto coil, starter, points, clutch, hell, even the cam and rockers if I need to)
Offline Kevin
Re: CB400F Engine swap due to poor compression?
« Reply #1 on: June 10, 2020, 03:01:15 PM »
I would swap it.
It's not that difficult to do.
Then you can do a rebuild of your original motor.
Sent from my SM-N960F using Tapatalk
A couple of 400F's and a
'98 Suzuki Intruder VS1400 ~ for long rides
« Reply #2 on: June 11, 2020, 07:41:51 AM »
Well, it looks like the engine with his compression has at least two leaky valve stem seals on the exhaust side, so I'd be trading one set of problems for another.
« Reply #3 on: June 11, 2020, 08:13:35 AM »
Consider swapping the seals for new if the guides are usable.
« Reply #4 on: June 11, 2020, 10:32:32 AM »
That's true. And the head doesn't need to come off fur that, right?
Would you change them all while you're in there?
« Last Edit: June 11, 2020, 11:01:36 AM by Alaxy Galaxy »
Offline Tim2005
« Reply #5 on: June 11, 2020, 11:19:24 AM »
Yes, you can, you just need to make up some sort of lever arrangement to compress the valve spring. You can actually get away with bringing the piston to tdc and resting the top of the valve on it too. I've done it on a 400f with the motor in the frame.
« Reply #6 on: June 11, 2020, 11:53:17 AM »
Thanks. I already have a jig like that that I made to remove the springs on this motor. The fact that it's not in frame makes it easier.
Again though, would you replace them all or just the obviously leaky ones?
Offline Tim2005
« Reply #7 on: June 11, 2020, 02:44:12 PM »
From what I remember it was pretty easy and quick to do, so I'd do all 4 while I have got the opportunity
« Reply #8 on: June 11, 2020, 08:28:31 PM »
Can they be removed without special tools and without removing the head?
Offline Bodi
« Reply #9 on: June 12, 2020, 10:35:13 AM »
There are no seals on 400F exhaust guides in my experience, although the fiche shows them.
« Reply #10 on: June 12, 2020, 11:49:47 AM »
350bsome didnt have exh seals 400 did
« Reply #11 on: June 13, 2020, 12:59:34 PM »
This motor does not have seals on the exhaust side. I will order some and see if I can fit them nonetheless.
Offline Kevin
« Reply #12 on: June 13, 2020, 04:04:57 PM »
I don't think they will fit, the valve guides are not machined to accept them on the 400F.
« Reply #13 on: June 13, 2020, 07:11:52 PM »
You're right. The parts fiche must be wrong in this case. In any event, I'll leave it as is and if the intake seals seem to be problematic down the road, it's pretty simple to change them. Might even be able to do so with motor in frame.
Now I just have to decide whether I want to remove an engine that I know works in order to replace it with one that I know nothing about...
Offline The Lone Builder
  • "Still running against the wind"
    • Belfast-2-Belfast-By-Bike
« Reply #14 on: June 16, 2020, 05:09:31 AM »
Hi Alaxy,
FWIW, the parts guide I have doesn’t show seals on the exhaust side. Happy to send you the whole doc if you’d like, but it’s 2MB so may be a bit big to attach.
Are you going to part out the seized engine? I’m struggling to find some parts for my resurrection, so I’d be interested if you are. Main missing bits are the cam chain bar, the clutch arm and its spring.
Cheers.
CB750 K2 - From Belfast-2-Belfast
CB750 K1 - The less, said the better!
CB450 K1 - Stalled.
CB400F Supersport - Not Rusty any more!
Follow my journey through Africa @ http://Belfast2BelfastByBike.com
« Reply #15 on: June 16, 2020, 06:16:34 AM »
Hi Alaxy,
Cheers.
Of that is interesting. What market is that parts fiche from?
As for the engines, neither is stuck. I've got a running engine with sub par compression and oil consumption, and a spare motor with good compression but otherwise untested. I am not planning to part out either at this point.
« Reply #16 on: June 16, 2020, 02:03:46 PM »
I’m not sure, but I have another document that shows, presumably, the models it applies to.
It also shows no exhaust-side seals.
The first one came from here:
http://www.manualedereparatie.info/categorii/honda.html
« Last Edit: June 16, 2020, 02:05:55 PM by The Lone Builder »
CB450 K1 - Stalled.
