Author Topic: Noisy Engine  (Read 2119 times)
Offline Zeke
Noisy Engine
« on: June 10, 2005, 07:04:19 AM »
Guys:
I'm probably just paranoid, but.....
Last week I bit the bullet to fix my oil leaks around the CAM cover.
I got 10 or so new copper washers, and a helicoil kit to fix a stripped bolt.  Everything went well, except of course the fact that I stripped another bolt torqueing them down.  My torque wrench is in inch-lb units and designed for small bolts.
I swear, if I had the cam cover out again I'd helicoil all of them.  It wasn't designed for proper thread depth using cast aluminum.
Anyway, I readjusted the valves as usual, using the go/no-go system I read about here -- I'm getting good at it now.
Then I fired it up.  Ran good warming it up, but I have to admit when I slowed the idle down it sounded a bit noisy to me, valve-train wise.
What do you think?  Am I just worrying again?  I didn't readjust CAM chain because I didn't loosen it.  The engine only has about 1500 miles on it since rebuild finished a month ago.
out,
Zeke
Offline kghost
Re: Noisy Engine
« Reply #1 on: June 10, 2005, 03:02:27 PM »
If you used a new Cam chain during your rebuild, now is the time to adjust it. A new chain will stretch some.
Stranger in a strange land
Offline Zeke
Re: Noisy Engine
« Reply #2 on: June 10, 2005, 03:20:49 PM »
I didn't use a new chain, but tonight I'll do it again just to make sure.
Zeke
Offline Lumbee
    • My pics...
Re: Noisy Engine
« Reply #3 on: June 10, 2005, 08:34:48 PM »
...hey man...gotta have faith in u'r work...if u know u torqued everthing down right...twist that MOFO and let the chips fall where they may!!!
"I'm not a welder, but I play one on HondaChopper.com"
Offline Zeke
Re: Noisy Engine
« Reply #4 on: June 11, 2005, 12:43:34 PM »
Yeah All, it's fine.
I did have two breakdowns today though.  And I was supposed to work today.
I'm gonna detail my breakdowns in another thread.
Zeke
Offline kghost
Re: Noisy Engine
« Reply #5 on: June 12, 2005, 02:50:17 AM »
Wow, you must have a fragile mind. Are the pills the doctor gave you helping with the breakdowns?
 ;)  ;D  ;D
