Author Topic: Starter magnetic HONDA CB650 Rc03  (Read 1420 times)
Offline albev
« on: June 25, 2020, 01:58:34 PM »
Hi there
Im trying to reorganize the electrical system, and Im confused about the leads right position into the starter magnetic.
Has someone some advices or a diagram?
Thanks
Re: Starter magnetic HONDA CB650 Rc03
« Reply #1 on: June 25, 2020, 11:37:17 PM »
I think we have a language problem? I don't fully understand your question. Can you attach a picture of the magnetic switch? (Here, we call that part a solenoid ;))
Offline albev
« Reply #2 on: June 26, 2020, 01:00:35 AM »
Yes Im speaking about the solenoid
I would like to understand the right leads position in the four connectors
« Reply #3 on: June 26, 2020, 06:42:40 PM »
Do you have the 4 wire plug that plugs into the solenoid? In the pic, the bottom 2 positions appear to be connected, so that would be where the solid red wire that supplies the ignition switch, and the red/white wire would be from the output of the rectifier, providing the charging current to the battery through the fuse. The upper 2 positions would be the solenoid coil terminals; 12v on one and ground on the other when the starter button is pressed.
Offline randomguy81
« Reply #4 on: February 20, 2022, 07:43:09 PM »
Did you figure this out - have the same solenoid
