Author Topic: CB500K0 alternator cover bolt sizes  (Read 657 times)
Offline dazemc
« on: June 30, 2020, 04:22:17 PM »
Correct me if I'm wrong but the longer bolts are M.6, 1.0 fine pitch, 65 mm length and the short ones are 25mm length? All of mine are stripped so before I take my Dremel to it, I wanted to make sure I order the right bolts.
Sent from my SM-N950U1 using Tapatalk
1971 CB500
Offline river
Re: CB500K0 alternator cover bolt sizes
« Reply #1 on: June 30, 2020, 07:45:07 PM »
Believe that to be true on the longer ones (CMSNL does say 65) but they list the others as 32 and not 25.
Squirrel 1.0 http://forums.sohc4.net/index.php/topic,127186.2050.
ml
Squirrel 2.0
http://forums.sohc4.net/index.php/topic,176846.msg2055831.html#msg2055831
Squirrel 3.0
http://forums.sohc4.net/index.php/topic,185362.msg2146449.html#msg2146449
Offline dazemc
« Reply #2 on: June 30, 2020, 08:15:20 PM »
Cool, thank you. I was able to get one of the longer ones out so I was just guessing on the shorter ones. Now I know for sure.
1971 CB500
