Author Topic: CB500t starter solenoid  (Read 1260 times)
Offline cb500t_88
« on: July 01, 2020, 09:02:23 PM »
So the other day in changing up my rear turn signals and accidentally touched the ground to one of the fuses. thankfully only that ground wire sparked and caught fire but spared the bike and everything else from what I can see. I have since replaced this ground.
But in the panic, I pulled out a few wires and now I'm not sure where they go. the wires in question are for the starter solenoid, being paranoid/cautious about wiring it wrong.
the two red wires were in a black sleeve connected to the plug in pin with butt connectors. one of them seem to be connected to the starter solenoid (can someone confirm that?), where should the other wire go?
Picture below for two wires in question.
https://imgur.com/0Na8we0
Re: CB500t starter solenoid
« Reply #1 on: July 01, 2020, 10:55:52 PM »
Cant see your pic cant you load it direct
Offline robvangulik
  • Honda Fourever
« Reply #2 on: July 02, 2020, 01:45:04 AM »
Here you go...
« Reply #3 on: July 02, 2020, 02:14:11 AM »
Never seen anything like that before, you will have to get a proper wiring diagram and trace every wire im afraid
Offline Rollthelosingdice
« Reply #4 on: July 02, 2020, 03:47:36 AM »
Here's what my 500T looks like.
"'Reality' is just a word, and you shouldn't use it without quotation marks around it anyway." - Joseph Campbell
Offline cb500t_88
« Reply #5 on: July 02, 2020, 07:45:42 AM »
the black wire housing with the red end, has the two wires in asking about, where is that connected to?
To me it looks like a two pin plug and it's connected to the same end on the starter solenoid?
« Reply #6 on: July 03, 2020, 08:01:50 AM »
Yeah connect that to your solenoid with the wire that goes to the positive on the battery.
