Author Topic: do all steering bearings kits include spacers? WHICH ONES DO??  (Read 3647 times)
Vasil
« on: February 14, 2007, 07:22:01 AM »
I'm looking into ordering stering head bearings for my 550K.
Are all bearing kits sold by vendors the same? Do they all come with the required spacers/washers? If I get the kit from partsnmore.com will it come with the spacers?
Comparison:
https://www.partsnmore.com/cat_index.php?model=cb550&category=chassis
vs
http://www.z1enterprises.com/detail.aspx?ID=2778
I dont want to buy a bearing kit only to discover that its incomplete and I that have to hunt for spacers....  :-\
« Last Edit: February 15, 2007, 06:06:17 AM by Vasil »
Offline 736cc
Re: do all steering head bearings kits include spacers?
« Reply #1 on: February 14, 2007, 07:53:20 AM »
It looks complete. Have you ever replaced steering stem bearings?
Vasil
« Reply #2 on: February 14, 2007, 09:50:45 AM »
736cc,
No I haven't but I've been reading posts on how to do it....
Offline mrbreeze
  • Not your average
« Reply #3 on: February 14, 2007, 08:47:29 PM »
I noticed that Z1 sells 2 different kits....KL and All Balls. All Balls has everything....KL has everything but seals. I'm gonna get the All Balls kit .
MEMBER # 257
Cursed1
« Reply #4 on: February 14, 2007, 08:57:54 PM »
I have the All Balls kit.  Does anyone now if you need to use the spacers? If so where do they go top or bottom of the neck, and above or below the bearing?  I have a 74K Honda 750.   Thanks in advance!!!!
Offline mrbreeze
  • Not your average
« Reply #5 on: February 14, 2007, 09:15:03 PM »
The spacer is supposed to go below the bottom bearing but you have to measure the old bearing stack heighth to determine which spacer to use (sounds kinda goofy to me but I guess I will cross that bridge when I get to it).
MEMBER # 257
Cursed1
« Reply #6 on: February 15, 2007, 05:27:31 AM »
I was wondering if someone has already done it.  I have tossed out all of the parts that made up the neck bearing assembly.  Those ball bearings scatter as soon as you move the neck a half an inch.  If anyone has some insight that would be great!
Offline super pasty white guy
  • I'm not really a
  • 1976 750 F
« Reply #7 on: February 15, 2007, 05:39:07 AM »
I replaced mine with an All Balls and don't think that I needed any spacers at all...  but it's been awhile.  If you don't get any more definite responses, I'll go out and brave the cold to take a look.
dave
Vasil
« Reply #8 on: February 15, 2007, 06:05:14 AM »
Could someone please chime in where they got their bearing kits and did the kit include the spacers...
Example:
Pro-Flo Bearing kit = spacers / NO spacers??
CRC2 Bearing kit = spacers / NO spacers??
Z1 Bearing kit = spacers / NO spacers??
Denis Kirk Bearing kit = spacers / NO spacers??
Parts n More Bearing kit = spacers / NO spacers??
--this would be a great database for future reference--
« Last Edit: February 15, 2007, 12:05:41 PM by Vasil »
Offline spitfire
Re: do all steering bearings kits include spacers? WHICH ONES DO??
« Reply #9 on: February 15, 2007, 07:15:34 AM »
Got my kit from David Silver Spares and it included a spacer, for a CB750F1 though, see photos.
Cheers
Dennis
Wirral UK
1976 CB750F1 bought new in 76
1977 CB750F2: Restoration started
1964 BSA A65R: Waiting restoration
My gallery is here: http://www.sohc4.us/gallery/v/members/personal/spitfire/?g2_navId=x5a30f7b6
Cursed1
« Reply #10 on: February 15, 2007, 04:18:15 PM »
Example:
I bought mine off of Ebay from Cyclexchange.  They were brand new All Balls 45.95 shipped to my door.  He is selling them all of the time.  I would do a search.  The All Balls set comes with spacers.
Anybody know if you need the spacers?
Offline SWEETPEAUK
« Reply #11 on: February 16, 2007, 02:55:53 AM »
Can anyone measure the spacer's thickness and bearing numbers. My bearing supplier has taper bearings with a dust shield built into the bottom of the bearing, this stops road crap getting into the bottom race.
They are made by Koyo and have fitted them to my GS1000, there is more drag when moving the bars because off the shield in the bearing. Also cheaper than buying a kit. will post picture later
Offline RRRToolSolutions
  • I love old Japanese bikes!
« Reply #12 on: February 16, 2007, 01:05:21 PM »
I've done it on several different bike makes. The roller bearing is a straightforward install, but as Mr. Breeze said - you need to have the old, lower bearing assembly so youcan compare stack-height. You simply remove the upper and lower races from the steering head of the frame, remove the race from the tree, apply grease to the bottom race, lay the 18 or 19 1/4" ball bearings (I forget how many) adnd you measure the lower ball bearing assembly height. You go to the "new" tapered bearings box and you lay the rubber/seal (dust) washer down first, then the bottom race down 2nd, then the tapered bearing narow side up, and then the upper-bottom race (cup side down of course) and take a measurement. This difference is your shim/washer requirement. The washer will go on the stem first so your rubber dust washer is always up next to you tapered bearing's bottom end. All you are doing is making sure the steering stem is in the same height posiition as it's designer meant for it to be. You must have the right amount of threads att he top to hold the nut, they don't want to change geometry, and it's really a straight forward thing - no magic tools needed.
I will add only that if you have your stem powdercoated or painted - that bottom race and tapered bearing "will not" go over the stem. A trick I use is to put the stem in the freezer over night and the race/bearings slip right on.
Go for it.
Regards,
Gordon
« Last Edit: February 16, 2007, 01:08:33 PM by Ilbikes »
Kaws, Hondas, Yamahas, and Suzukis - especially Kaws
Offline shoemanII
  • just another bike nut
« Reply #13 on: February 16, 2007, 02:36:24 PM »
got my tapered roller set from partsnmore, '78cb750k.  spacer supplied, no install problems.  if i recall the install instructions correctly, if your bike needs a spacer, it will be included in the kit.
bobp
'96 ducati carb'd 900ss/cr
'72 dt2
'77cb550k frankenberry:  '77cb550k frame, '78cb550k engine, '78cb550f tank, unknown front-end
Offline Jinxracing
  • It's hot shit, not
  • '70 CB750 K1
    • The Hairy Nickel
« Reply #14 on: February 16, 2007, 02:45:23 PM »
I used an All Balls kit on my '70 CB750 K1. It came with two spacers of different thicknesses, dust seal, and both bearings (of course). The instructions were fairly detailed about how to measure the lower bearing stack to decide which (or both, or neither) of the spacers was needed. My measurements indicated the thick spacer, and it all went together just fine. Much less complicated than it sounds. The hardest part of the whole operation was pressing the bearings onto the tree and the races into the head tube. I put the tree into the freezer overnight to shrink it a little bit.
I had already thrown away my old bearings, races, and balls. I just dug the races out of the trash along with three balls. The three balls were enough to hold the old lower race & cage apart for measurement.
HTH
Jinx
–Captain Horatio Hornblower
www.thehairynickel.com
Cursed1
« Reply #15 on: February 16, 2007, 06:51:43 PM »
HTH
Jinx
So dust shield, larger of the two spacers and then the bearing.  Correct?  Thanks for the response.  Anybody know if there is a difference between the 70' model year that he is describing and the 74' that I currently own?  Thanks!!!
Offline chung
  • Giddy Up
    • chungfucycles.com
« Reply #16 on: February 16, 2007, 09:57:46 PM »
It has been a while. But as I recall the bike will tell you if it wants a spacer. And it will tell you whether it wants it on the bottom or not. Look at the top nut dude. Not trying to be an #$%* but I had to figure it out at home with no help. Step up to the plate batter!
Member#2815
1971/76 CB750 Hack @970cc,
1975 CG750K
1970 CB350,
1972 YDS7, 250
1972 YR5, 350
1977 RD400,
1978 Piaggio Grande/Batavas HS50 Special
1981 XS650 Special II
Vasil
« Reply #17 on: February 18, 2007, 06:17:23 PM »
anybody else want to contribute as to where they bought their bearings and if their kits came with spacers?  ???
Cursed1
« Reply #18 on: February 20, 2007, 09:09:20 PM »
I will be installing the bearing kit as instructed above.  Dust shield, larger of the two spacers and bearing.  I will write back how it comes out.  Thanks to all that were informative.
Offline mrbreeze
  • Not your average
« Reply #19 on: February 20, 2007, 09:29:58 PM »
Wait a minute.....hold the phone......I believe the order is spacer first....then seal...then bearing. Am I correct???
MEMBER # 257
Offline Jinxracing
  • '70 CB750 K1
    • The Hairy Nickel
« Reply #20 on: February 20, 2007, 09:31:27 PM »
Be careful...you should really measure you're particular bike as per the instructions. It makes sense to think that there are two different thicknesses of spacers because different years/applications may differ. I only bring this up because I don't want to be responsible if your plan goes blooey.
Jinx
Cursed1
« Reply #21 on: February 21, 2007, 08:44:47 PM »
Jinx
Well the problem is that I no longer have any of the bearings or anything that is related to it.  That has seen the trash way sooner than when I received the bearing kit.
