Author Topic: Airbox rubber hoses routing  (Read 743 times)
Offline Sri Nair
« on: July 04, 2020, 02:17:36 PM »
Just joined the forum after going to replace the air cleaner on 1976 CB400F and noticed that the airbox was quite fouled with oil and smelling of gas. Further inspection showed that the rubber hoses underneath were going nowhere. The manuals don't show the routing of the hoses. I would appreciate some help with ensuring that the hoses go where they are supposed to.
Offline newday777
Re: Airbox rubber hoses routing
« Reply #1 on: July 04, 2020, 02:31:39 PM »
Welcome Sriman
If it's the hoses off each carb bowl?? They are drain hoses for the bowl overflow and drop between the engine and the swingarm
Stu
My current rides
Prior bikes....
Offline Sri Nair
« Reply #2 on: July 04, 2020, 05:29:20 PM »
Thank you, Newday777. Glad I found and joined the forum.
No, not the hoses coming off the carbs. One bulk hose coming off the cylinder head cover and ending under the airbox - does it plug into anything, maybe the side of the little cup at the bottom of the airbox? and another shorter piece at the bottom of the cup.
