Author Topic: Oil pressure question - cb750  (Read 1117 times)
Offline macvit7906
« on: July 04, 2020, 02:45:40 PM »
Happy 4th everyone!
Getting prepared to start my rebuilt engine this week. A few months ago had 60psi oil pressure on a bench test with the starter cranking the engine.
Got the engine in the frame.
Had to re-prime the oil pump because of an air lock (tipping engine to get into frame) - pump wasn't taking oil
after re-priming, the pump takes oil but only reading 20 psi on the oil pressure gauge - visibly getting oil to the top end.
Same oil pressure gauge, same starter. What could cause the 40 psi drop in oil pressure from bench to engine? The only change I made was from 10w-50 to 10w40 oil.
Theoretically, the  oil pressure should get higher with higher RPMs correct? Am I safe to do first start up in this condition or should i try to get 60 psi on the starter first?
Re: Oil pressure question - cb750
« Reply #1 on: July 04, 2020, 04:00:06 PM »
You have pressure. The starter is not that strong. Fire it up. Watch it pop to 70psi.
« Reply #2 on: July 05, 2020, 07:11:15 AM »
 Those first start-ups are always a little fretful but rewarding. Seems my projects never have a pressure gauge but I always look into the oil tank with a flashlight right away checking for good circulation,bubbles and other good stuff. Good Luck when you hit that button !
Offline macvit7906
« Reply #3 on: July 05, 2020, 09:48:59 AM »
Appreciate it guys. I guess I'll just fire it up.
Just bothering me that there is a 40 PSI pressure drop from bench to frame. Could switching to 10w-40 oil do that?
Also i suppose the temperature is warmer now compared to when i did the bench test.
Offline Bowswell
  • CB750K1,CB750 K4,CB350F,CB400t1,meanstreak
« Reply #4 on: July 06, 2020, 09:24:20 AM »
I use 20/50w and cold 60lbs and hot engine it?s 20lbs in idyl.
