Author Topic: '78 CB550 - CARBS: How much does needle height affect mixture  (Read 586 times)
Offline jury08
I'm running a 4into1 exhaust and knock-off K&N pods. I've replaced carb boots and manifold o-rings and and everything is air tight. I've got 42 slow jets and 110 main jets. Bike still runs lean and hot even with the mixture screw 3 turns out. My needle is currently at the 3rd position. Is the change in needle position minimal enough that I should just go all the way to the 5th position or does it make sense to go to the 4th?
Re: '78 CB550 - CARBS: How much does needle height affect mixture
« Reply #1 on: July 06, 2020, 09:55:03 AM »
1 change, 1 notch at a time
Offline Scott S
« Reply #2 on: July 06, 2020, 02:17:24 PM »
http://forums.sohc4.net/index.php/topic,182280.0.html
 Some people even shim the needles with thin washers,  for 1/2 a position adjustments.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
