Poll
i have a 1978 cb 750 f2n  which has a early engine fitted  a 1969 cb 750 ko
leave it as is and restore bike
2 (28.6%)
sell engine and fit correct engine
5 (71.4%)
Total Members Voted: 7
Voting closed: July 13, 2020, 03:20:12 PM
Author Topic: engine  (Read 1065 times)
Offline okey
engine
« on: July 08, 2020, 03:20:12 PM »
bike is in good condition so well worth restoring
Offline Alan F.
Re: engine
« Reply #1 on: July 08, 2020, 04:05:07 PM »
Rolling resto as is, and enjoy the ride. Sell that early engine later when it's running sweetly and fit the correct engine to your bike on the same day.
« Last Edit: July 08, 2020, 07:55:49 PM by Alan F. »
Re: engine
« Reply #2 on: July 08, 2020, 07:13:22 PM »
What number is the engine.. last 5  numbers will do. If you want to hide a few do this 16, 7××
Re: engine
« Reply #3 on: July 09, 2020, 08:22:05 AM »
 If its an early sandcast engine and your not into those I would sell it and you would probably have enough money to buy another engine and another bike also to play with. Some value also in a K0 engine to the right guy looking for a certain serial number range. Any evidence its ever been repaired around the countershaft sprocket area ?
Offline Bankerdanny
  • Endeavor to persevere
Re: engine
« Reply #4 on: July 09, 2020, 08:26:53 AM »
The F2 engine was the most powerful, but has a design flaw. The K0 engine is the next hottest, so a good replacement. However as Frank and Eric mentioned, if the serial number is early enough, about 7400 or less, and the case is original, the engine alone is worth the cost of super clean F bike or a solid runner K6 or earlier.
Offline okey
Re: engine
« Reply #5 on: July 09, 2020, 01:45:07 PM »
Engine not that early I’m sorry to say  cb750e 1107706  appears to be 1969 cb750ko r
That’s what I have been told have split cases and found two u/s bearings each side of primary gears but have to check on the rest in due time cases all look good
Re: engine
« Reply #6 on: July 09, 2020, 02:09:13 PM »
 Are you sure the number is not 1007706 instead of 1107706. Not really a 110 prefix out there. 7706 would be a good thing.
Re: engine
« Reply #7 on: July 09, 2020, 03:25:55 PM »
K1 should have that number I think, externally looks like a K0..
