Author Topic: m unit blue and m lock wiring  (Read 1981 times)
Offline guamjake
« on: July 11, 2020, 05:32:40 PM »
Hi, plan on using M unit blue and m lock together.  I have looked over the wiring diagram for the m lock and trying to see how these two will work together. Does anyone have a diagram?
Offline calj737
  • Moderator
  • I refuse...
Re: m unit blue and m lock wiring
« Reply #1 on: July 12, 2020, 03:55:07 AM »
This should be sufficient
Offline guamjake
« Reply #2 on: July 12, 2020, 08:24:58 AM »
Thanks for the response, so I do not need to use the included relay ? or do I?
Seems the wiring diagram that comes from Motogadget is for when you're integrating it into a factory system. I am using a ricks reg/rec, m unit blue, and revival cycles distribution block.
Offline calj737
  • Moderator
  • I refuse...
« Reply #3 on: July 12, 2020, 09:47:36 AM »
The fuse is advised, the relay is superfluous.
Offline guamjake
« Reply #4 on: July 12, 2020, 01:23:23 PM »
will ensure to include the fuse and will not use the relay!
Offline guamjake
« Reply #5 on: July 15, 2020, 05:49:11 PM »
Cal, the Fuse you are talking about is it the 1amp fuse or the 40amp main fuse ? I have mine getting power after the 40amp main fuse at the m-unit. just want to clarify thanks.
Offline Seanery
« Reply #6 on: July 15, 2020, 06:46:06 PM »
The new units are slightly different than the one in the diagram. There is a second Aux, and a few other variations. And for some reason they changed the name.
But for the purpose of the OP it's the same.
Revival Cycles has a decent video that may help with wiring design.
