Author Topic: Quick question about plating  (Read 835 times)
Offline AlekStooge
  • can't afford cheap stuff
« on: July 14, 2020, 02:16:25 PM »
How much thickness does plating add? I'm rebuilding my carbs and I want somethings Nickle plated. I wanted to make sure threads and thicknesses would be fine.
The pieces I'm most concerned with are the throttle and choke shafts.
Here is my build thread if anyone want more details.
http://forums.sohc4.net/index.php/topic,183457.0.html
Offline 69cb750
Re: Quick question about plating
« Reply #1 on: July 14, 2020, 03:35:35 PM »
.001" to .005"
If you plan to plate slides that move up and down measure od of slide and id of bore, you also need raw steel on the slide
Offline AlekStooge
« Reply #2 on: July 14, 2020, 03:47:12 PM »
I'm not doing the slide. I think I'll do the choke plates though.
