The SOHC/4 World Tour is in under way.
Is there a difference in piston rings between the pre-76 models and the 77-78? Thanks!
You need a flashlight to illimunate the area close to cam chain sprocket. Look like written with a pencil. Crank bearings + rods. Visible in specific angles only.I'm sure green shells will work fine!
Got all my parts back from aqua blasting, everything looks great!
