Author Topic: Reinstalling rear wheel (73' CB750)  (Read 715 times)
Offline samfig
  • Sr. Fig
« on: July 20, 2020, 10:43:18 AM »
I've searched a considerable amount for this information but I can't seem to find the correct procedure.  How the heck do you reinstall the rear tire??  I have the original pipes on and they are blocking access to install the axle when it is in line with all the holes.  Thoughts?
Do I have to remove the exhaust on one side?
Any help would be greatly appreciated.
-Sam
-1973 CB750
Offline 69cb750
Re: Reinstalling rear wheel (73' CB750)
« Reply #1 on: July 20, 2020, 10:55:42 AM »
Remove ends of swing arm, two bolts, wheel comes straight back.
Offline samfig
  • Sr. Fig
« Reply #2 on: July 20, 2020, 11:00:26 AM »
I've got the wheel out, my question is how to get it back in and still slip the chain over the sprocket.  When I do this the chain is too tight when I pull back on the rim and it won't clear the swingarm to slide into the channels.
-1973 CB750
Offline Robbo
« Reply #3 on: July 20, 2020, 11:12:19 AM »
Slide the wheel into the channels and then put the chain on.
1973 CB350 Four, 1975 CB550K
« Reply #4 on: July 20, 2020, 11:22:02 AM »
 DO YOU HAVE the tin cover on outside of sprocket ?  Put the wheel under swingarm opening, get the chain onto the tin cover,  and start adding axle and spacers, then lift into swimgarm. Then sliding wheel all the way to front, chain should  go on sprocket.
 That is for a riveted or one piece chain.
« Last Edit: July 20, 2020, 11:25:15 AM by 754 »
