Boy that's weird on my 73 the shaft holes to straight through from one side to the other going through the cam gear well on the under side of the cover you can run a rod in the rocker shaft cover #1 and come out on #4. I will use locktite on those cover screws thanks. Maybe my 2 and 3 holes have a taper or step towards the cam gear end?
Thanks
Gary
