Author Topic: Battery not charging  (Read 2287 times)
Offline nanahan
« on: July 23, 2020, 07:49:04 PM »
Hi guys
So yesterday I rode for about 100 miles and everything was working fine.
I have a battery tracker that tells me how is the battery through an app, during those 100 miles the battery was charging and at 100%
Today I rode for maybe 10 minutes, and the app notified me the battery was not charging.
I took the gas tank off and started looking for a loose wire or something.
As I was moving the cables the battery started charging again but stop and go went I wiggles the cables.
My question is, would it be a faulty connection or cable  from a ground cable or a power cable that would cause this?
Offline BenelliSEI
  • 1969 cb750
Re: Battery not charging
« Reply #1 on: July 24, 2020, 05:30:16 AM »
How does your phone connect to the bike? Any chance that is faulty?
Offline nanahan
Offline nanahan
« Reply #3 on: July 24, 2020, 12:32:30 PM »
it connects to the battery and through bluetooth to the phone.
Sent from my iPad using Tapatalk
Offline nanahan
« Reply #4 on: July 27, 2020, 02:32:37 PM »
So I found the issue.
I noticed there were four hot wires connected with 1 connector and four ground wires connected the same way. The connectors used wasnt gripping strong so the wires were loose.
I replaced these connectors with Solder seal connectors (they are superb to any other types) and once i started the motorcycle, the battery was charging as before.
