Quite simple, you push the sprocket on until you can see the groove. Then you slip on the lockplate you did not shown, turn it to line up with the threaded holes, then put the two small bolts in.
However. ..
...the 75 f looks like short shaft, later are longer. Tell us what motor is going in what frame, and we can tell you what to do to line up the sprockets
