SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
SOHC/4 Shop
Home
Help
Login
Register
Donate
Tech Forums
Other Bikes
Topic:
1975 CB360T start & idle problem
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: 1975 CB360T start & idle problem (Read 945 times)
HammerSchlagen
Full Member
on:
August 04, 2020, 08:52:50 AM »
Good Afternoon,
I recently purchased a 1975 CB360T, overall in decent shape. It fired up from cold and I test rode before purchase, took some messing around with choke to get it to idle.
I'm having trouble getting the bike to idle and it's been dying once it gets hot, I have to keep constantly on throttle to keep it alive. But before I even address that.
Seller put new battery in the bike, this model.
https://www.amazon.com/POWERSTAR-12N9-4B-1-Motorcycle-Battery-Replaces/dp/B00XNK8Y52
I put the multimeter to it and it is only at 4V. This could be because I kept using the electric starter but regardless I need to charge it. Can I use my portable car charger to charge this battery?
https://www.amazon.com/NOCO-GB20-UltraSafe-Lithium-Gasoline/dp/B015TKPT1A
Let's say that charger is safe and I charge up to 12.6+V, if the idle problem persists where would you recommend I begin my troubleshooting?
Thank You
Logged
HammerSchlagen
Full Member
Re: 1975 CB360T start & idle problem
Reply #1 on:
August 04, 2020, 10:16:50 AM »
Normally I understand this would indicate the battery has reached the end of it's lifespan, but this is a brand new battery. Could I have just drained it from the electric start?
Logged
low-side
Enthusiast
Reply #2 on:
August 05, 2020, 06:58:49 AM »
The electric start should have stopped working long before the battery got that low. You likely have a parasitic drain somewhere.
Logged
Print
Pages: [
1
Go Up
« previous
next »
Tech Forums
Other Bikes
Topic:
