Author Topic: CB400F - Primary drive chain guide  (Read 545 times)
Offline The Lone Builder
  • "Still running against the wind"
    • Belfast-2-Belfast-By-Bike
« on: August 04, 2020, 10:35:13 AM »
Just started putting my engine back together.
Can someone advise which way the primary drive chain guide fits in the lower case?
Outside the two bolts, one end is longer than the other and it has a small hole/depression in it.
Does this go at the bottom, by the oil pan, or the other way round?
CB750 K2 - From Belfast-2-Belfast
CB750 K1 - The less, said the better!
CB450 K1 - Stalled.
CB400F Supersport - Not Rusty any more!
Follow my journey through Africa @ http://Belfast2BelfastByBike.com
Offline Alaxy Galaxy
Re: CB400F - Primary drive chain guide
« Reply #1 on: August 04, 2020, 10:52:14 AM »
Can it be seen by removing the oil pan? If so, I could check my spare motor.
« Reply #2 on: August 04, 2020, 11:33:52 AM »
You might just be able to see the end and maybe feel if that little hole is there if you can’t see it.
That’d be great if you could.
CB450 K1 - Stalled.
Offline Kevin
« Reply #3 on: August 04, 2020, 11:38:57 AM »
The dot goes toward the oil pan.
Sent from my SM-N960F using Tapatalk
A couple of 400F's and a
'98 Suzuki Intruder VS1400 ~ for long rides
« Reply #4 on: August 04, 2020, 11:51:41 AM »
Wow! That’s a great pic!
I was just about to say I had found the answer in Nurse Julie’s rebuild thread on teh UK site:
http://www.sohc.co.uk/index.php/topic,14049.105.html
However the pic there was not as smart as yours  ;D
CB450 K1 - Stalled.
Offline Kevin
« Reply #5 on: August 04, 2020, 01:21:37 PM »
Thanks!
Nurse Julie is great, I had a brain fart and she was the first one who had the correct answer for me.
Good luck with your build!
Kevin
« Reply #6 on: August 05, 2020, 02:26:43 AM »
I wandered on down through the thread and there is a much better - read cleaner - pic further on.
CB450 K1 - Stalled.
