You can also check the horn at the battery. Power to positive and ground the other wire. If no beep, it is the horn. I have a 1972 CB750 which had a non-working horn. Took it apart (pretty easy to do), cleaned up the components, and put it back together. There is a nut inside that regulates the horn vibration. I messed with different degrees of tightness to get it to work properly. Last on is the cover.
