Author Topic: Cahababum's 1970 cb750  (Read 996 times)
Offline Cahababum
« on: August 07, 2020, 01:33:05 PM »
This is my 1970 CB750 with a K3 motor or so it seems by the serial numbers. I paid $150 for it, trailered it home and have started the full disassembly. I cut off the rear end a put in a hoop. I'm swapping the rear swingarm from a 1975f0 swing arm on to the K0. It will consist of a full swap of parts. Swingarm, Brakes and 18 inch rim. Here are some pictures of the bike when I got it home and now just about fully disassembled.
Excuse the mess, when your married with three kids I can't keep anything clean.
The bottom picture is how it looked when I picked it up. I guess they uploaded in reverse. The motor is free and on my harbour freight compression tester I'm right around 95PSI with out the carbs or exhaust attached. I've fully cleaned the carb and I'm in the process of reassembling those now.
« Last Edit: August 07, 2020, 01:36:29 PM by Cahababum »
Re: Cahababum's 1970 cb750
« Reply #1 on: August 09, 2020, 06:47:29 PM »
Welcome aboard. Is there a flat spot where your frame numbers are ?  Looking off a bit . Is there a thin metal tag on other side of the frame neck from those numbers  ?
The Sovereign Man
« Reply #2 on: August 10, 2020, 02:44:40 AM »
Nice score. $150 barely buys you lunch here in Australia, I’d have Buckleys & None getting a motorcycle for that money.
Offline Cahababum
« Reply #3 on: August 10, 2020, 06:05:38 AM »
No holes.. no flat spot nothing just the numbers stamped into the frame and no thin metal tag like all other bikes. It has confused me since I purchased the bike. The engine seems to be a k3 if going off the engine number but it doesn't match what is stamped on the frame.
Offline Cahababum
« Reply #4 on: October 27, 2020, 07:04:13 AM »
Long time update. I picked up a 1976 CB750A parts bike for $100, it came with the aluminum rims, front forks that can run dual front brakes. Still in the process of cleaning everything up.
Anyone looking for a cb750a Gas tank or Frame?
117035828-10223537325290351-3333582141529691602-o" border="0
<a target='_blank' href='https://imgbb.com/'>img upload[/url]
Offline Shtonecb500
    • Youtube profile
« Reply #5 on: November 03, 2020, 08:27:51 AM »
good scoop on the rims and dual disk, should clean up nice.
73/74'' CB500/550 resto-mod - sold
75' 750f 91' cbr f2 swap cafe - mock up
74' 750 chopper hardtail - complete - sold
74' CB750/836kit - Black mix & match - daily rider - always tweaking
71' cb500 K0 survivor - complete
71' K1 - CANDY GOLD/BROWN Winton kit - in process
