Author Topic: Removable engine mount  (Read 1126 times)
Offline Laids
« on: August 07, 2020, 07:14:30 PM »
I was looking at a K7 frame I just got, the engine was out but a case guard on the left side was still on. I noticed the engine mount was removable. It appears to be factory, anyone know the story behind this?
Offline beemerbum
Re: Removable engine mount
« Reply #1 on: August 07, 2020, 08:28:16 PM »
That's just the nature of the '77 and '78 CB750 K frame. For some reason, Honda chose to make some significant changes to a motorcycle that would change totally in '79. Does anyone know the corporate history for this time period?
Offline Laids
« Reply #2 on: August 07, 2020, 08:43:21 PM »
I also have a 78 and it has a traditional frame mount same as all other years. As well I have seen other K7s that do not have a removable mount.  :o
« Reply #3 on: August 07, 2020, 09:03:36 PM »
Some of them also have the engine serial number in line with the wheels.. ie turned 90 degrees,
Offline beemerbum
« Reply #4 on: August 08, 2020, 08:05:02 AM »
It would be very interesting to hear from our resident expert Hondaman as to why all these differences in '77 and '78 frames.
Offline jlh3rd
« Reply #5 on: August 08, 2020, 10:44:39 AM »
I believe this came up a while back in a discussion, and it appears the 77 only has this , yet that part is not on the fiche. It still shows the welded boss.
Yet you can barely make out the part on the honda guide pic.
Offline onepieceatatime
« Reply #6 on: August 08, 2020, 10:51:27 AM »
Here is that discussion:
http://forums.sohc4.net/index.php/topic,176458.0.html
1965 CA77
1972 CB750K Ol' Sarge
1974 CB450K7
1977 CB750K7
1977 CB750K7
1980 CB650C
1982 CM450A
1997 GL1500SE
Offline beemerbum
« Reply #7 on: August 08, 2020, 02:14:18 PM »
Thanks for posting. Learn something on this site every. Still wondering why Honda did that apparently for '77 only.
« Last Edit: August 08, 2020, 02:17:20 PM by beemerbum »
Offline BenelliSEI
  • 1969 cb750
« Reply #8 on: August 08, 2020, 07:11:04 PM »
This is definitely an “unsolved mystery”. From my investigation, it’s only on K7’s and I’ve seen some late ones with a standard lug! It’s a very well made part and my K7 is the easiest frame to pull or install the engine. I’ve never seen a definitive explanation.
« Reply #9 on: August 08, 2020, 07:28:04 PM »
Well they had 2 assembly lines far as I know, and they must have been prepping for the switch, coming soon to the DOHC..
Offline Laids
« Reply #10 on: August 12, 2020, 01:31:38 PM »
My theory is that the Honda engineer for the frames on the K7 was responsible for the removable mount and getting rid of the weep hole on the frame. He was then fired for 78, the removable mount was removed and the weep hole returned.
Just a theory :o
Offline beemerbum
« Reply #11 on: August 12, 2020, 01:46:58 PM »
Having made such a grievous engineering error, he brought dishonor upon himself and his family. Accordingly, he committed seppuku. Just a theory.
« Last Edit: August 12, 2020, 01:48:30 PM by beemerbum »
