Author Topic: Cb400f Misfires in the Rain  (Read 1550 times)
Offline philcarroll_1985
    • https://www.facebook.com/philcarroll.1985
« on: August 08, 2020, 01:26:20 PM »
Hello all, got caught in a heavy down pour last week, at first the bike misfired but carried on running, shortly after that it cut out altogether. Had 5 mins under a tree to dry off then the bike started fine as if nothing had happened. Can I weatherproof the bike in anyway? The pic was half hour before this incident, any excuse to post it
Sent from my VOG-L09 using Tapatalk
The Sovereign Man
Re: Cb400f Misfires in the Rain
« Reply #1 on: August 08, 2020, 02:03:49 PM »
Possibly spark plug leads and/or caps.
Get the bike running at home and spray the leads one at a time with a spray bottle (don’t drown everything) and see if you can replicate the problem.
Next culprit could be the coils.
Offline Nurse Julie
« Reply #2 on: August 08, 2020, 02:11:54 PM »
My 400/4 does that, its the type of rain we have in the UK 😁😁😁. Starts off as a four in dry weather, down to a triple in a light shower, a twin in a heavy sharp shower and a single in a deluge. Always manage to get home on one cylinder though 🤣🤣🤣
Trust me I'm a Nurse, I promise it won't hurt....much
« Reply #3 on: August 08, 2020, 04:35:49 PM »
WD-40 carried on the bike might help if you can give the wires and caps a good spray down after they get wet. Often periodically spraying things down is enough to help get you through a light rain next time. I usually replace wires and caps having these issues. Wonder why the 400 seems to have this issue?
Offline scunny
  • don't call me expert
« Reply #4 on: August 08, 2020, 05:09:47 PM »
My old brain recalls something about the length and location of the carb drain lines causing problems if they are to long.
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
Offline BenelliSEI
  • 1969 cb750
« Reply #5 on: August 08, 2020, 07:06:02 PM »
Do you have a good, well fitting gasket under the points cover?
Offline Trevor from Warragul
« Reply #6 on: August 08, 2020, 11:03:01 PM »
My CB350F used to do that after I washed it. The solution was to dry the motor with an air compressor. Doesn't help you much, though...
Trevor
1971 Kawasaki H1A
1972 Honda CB350F
1976 Moto Morini 3 1/2 Sport
1978 Honda CBX
1997 Suzuki Bandit 1200
1999 Ducati Monster 750
« Reply #7 on: August 08, 2020, 11:23:23 PM »
"They all do that sir" was the standard dealer answer in the day. Besy answer from list, carry WD 40 (NOT PENETRATING OIL) and liberally spray plugs, caps, leads, coils and anything else under there
Offline Deltarider
  • I'm back
« Reply #8 on: August 09, 2020, 12:53:35 AM »
I've seen two reports on this. Both concerned a CB550K3/4. May also be the case on other models. Remedy is simple: just cut a few cm of the tubes.
CB500K2-ED Excel black
« Reply #9 on: August 09, 2020, 01:08:24 AM »
Exactly what I was told by my Dad, he said it didn't like the rain but didn't think it would be quite so dramatic. Wd-40 it is
« Reply #10 on: August 09, 2020, 01:08:58 AM »
Nope, I'll have a look into that thanks
« Reply #11 on: August 09, 2020, 01:09:14 AM »
Any idea what the theory is behind that?
Offline Deltarider
  • I'm back
« Reply #12 on: August 09, 2020, 01:28:30 AM »
Often wondered myself. All I know, is it takes just a tiny droplet of water to hinder proper carburetion.
« Reply #13 on: August 09, 2020, 01:49:45 AM »
Remember the reports were K3/4 and they have different lean burn, therefore more finiky, carbs
Offline Old Moe Toe
« Reply #14 on: August 09, 2020, 01:54:08 AM »
I have got a truckload of "Water Damaged" Umbrellas going cheap.
Offline Erny
« Reply #15 on: August 10, 2020, 12:54:50 AM »
I had very similar issues on my CB750 K7. See posts from members wobbly & enwri that explained it - clogged upper body vents. It was confirmed recently on my K7, vents were totally clogged. Did not test again on wet road yet, but I believe this was route cause.
This is relevant for my PD41 carbs, but I assume can be similar on your carbs
http://forums.sohc4.net/index.php/topic,179023.msg2077590.html#msg2077590
CB750K K7 USA model (1977)
CB550K1 USA model (1975)
Offline mattsz
« Reply #16 on: August 14, 2020, 05:49:50 AM »
Be careful if you purchase another.  I bought a "brand new, NOS" cork gasket - after waiting a week for shipping, I found that it simply didn't fit.  Its overall diameter was either too small from the get-go, or it had shrunk over time (see pic).  I'm going to make my own...
Offline BenelliSEI
  • 1969 cb750
« Reply #17 on: August 15, 2020, 04:59:25 PM »
MattSZ. Old trick: If you soak an old, dry cork gasket in a pan of water, it will “grow”. Carefully clamp it in place and it will retain that shape when it dries.
Offline mattsz
« Reply #18 on: August 15, 2020, 05:21:38 PM »
You don't say!  I'll keep that in mind for next time - I already returned the "shrunken" one... and I've got some sheet cork from another project...
